RGB switch readout with lua
Posted: Wednesday 15 August 2018 13:48
by bitjeverkeerd
I use the lua script below to read out the on/off state and brightness value of a virtual rgb switch from Domoticz (and to control hardware).
This script is triggered when the value of the virtual switch is changed.
Is it also possible to read the rgb value with a similar lua script?
- Spoiler: show
- commandArray = {}
DomoticzDevice = 'RGBW' -- Naam van script en van schakelaar in Domoticz!!!
if devicechanged[DomoticzDevice] then
if(otherdevices[DomoticzDevice]=='Off') then
text = "RGBW = Off"
elseif(otherdevices[DomoticzDevice]=='On') then
text = "RGBW = On"
DomoticzValue = (otherdevices_svalues[DomoticzDevice])
text = "RGBW value = " .. (DomoticzValue) .. ""
print (text)
Re: RGB switch readout with lua
Posted: Wednesday 15 August 2018 14:45
by waaren
bitjeverkeerd wrote: Wednesday 15 August 2018 13:48
It is possible to read these RGB values but not very straightforward. I only know how to do this in dzVents
like here.
But even in dzVents it cannot be done in a standard way as the RGB data need to be read twice. (as explained in that thread)
Posted: Wednesday 22 August 2018 12:20
by bitjeverkeerd
I have created the following code (maybe not the most beautiful) but it works. Maybe it is useful for others on the forum.
DomoticzDevice = 'RGB' -- Naam van script en van schakelaar in Domoticz!!!
if (otherdevices[DomoticzDevice]=='Off') then
text = "Dimmer = Off"
elseif (otherdevices[DomoticzDevice]=='On') then
text = "Dimmer = On"
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local acolor = " "
ab='curl "http://192.168.51.111:8080/json.htm?type=devices&rid=12"' -- IP domoticz & IDX device
local jsondata = assert(io.popen(ab))
local jsondevices = jsondata:read('*all')
jsondata:close()
local jsonCPM = json:decode(jsondevices)
local acolor=jsonCPM.result[1].Color
print (acolor)
acolorj=acolor:gsub("}",",}")
for k,v in acolorj:gmatch('"(.-)":(.-),') do
--print(k,v)
if (k == 'b') then
rgbBlueValue = v
elseif (k == 'r') then
rgbRedValue = v
elseif (k == 'g') then
rgbGreenValue = v
DimLevel = (otherdevices_svalues[DomoticzDevice])
text = "Dimmer = " .. (DimLevel) .. " Rood = " .. (rgbRedValue) .. " Groen = " .. (rgbGreenValue) .. " Blauw = " .. (rgbBlueValue) .. ""
print (text)
