Converting my block to dzVents
Melotron
Post by Melotron »
Hiya.
I am trying to convert a blocky to dzVents.
How do I set the in between value of the Lux ??
        devices = {
            'Lux'
        if (domoticz.devices.Lux ( >= 3701 ) then
	       print("Lux is > 3701")
        if (domoticz.devices.Lux ( >= 401 and <= 3700 ) then
		    print("Lux is > 401 and < 3700")
        if (domoticz.devices.Lux ( = 0 and <= 400 ) then
		   print("Lux is > 0 and < 400")
I want it to set a few virtual switches after how light/dark it is.
I am only having the print command to see if it changes.
2018-08-12 12:46:00.818 Status: dzVents: Error (2.4.6): error loading module 'MI Day' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/MI Day.lua':
2018-08-12 12:46:00.818 ...pi/domoticz/scripts/dzVents/generated_scripts/MI Day.lua:7: unexpected symbol near 'if'
Andyf66
Re: Converting my block to dzVents
Post by Andyf66 »
Your syntax is a bit off. Try something like this
		devices = {
			'Lux'
        if (device.Lux >= 3701 ) then
        if ((device.Lux >= 401) and (device.Lux <= 3700 )) then
        if ((device.Lux >= 0) and (device.Lux <= 400)) then
Melotron
Post by Melotron »
Andyf66 wrote: Sunday 12 August 2018 13:01 Your syntax is a bit off. Try something like this
Thanks alot.
But now I need to learn how to handle values in dzvents.
Sat a few hours googling yesterday on the error and trying to figure out how it works.
I'm still lost
Status: dzVents: Info: ------ Finished MI Day
Status: dzVents: Info: Handling events for: "Lux", value: "20266.6666667"
Status: dzVents: Info: ------ Start internal script: MI Day: Device: "Lux (Virtual_Switches)", Index: 130
Status: dzVents: Error (2.4.6): An error occured when calling event handler MI Day
Status: dzVents: Error (2.4.6): ...pi/domoticz/scripts/dzVents/generated_scripts/MI Day.lua:9: attempt to compare number with table
		devices = {
			'Lux'
        if (domoticz.devices('Lux') >= 3701 ) then
I've even made the script as simple as possible.
The Lux are 20k+ so it should work.
Melotron wrote: Monday 13 August 2018 9:17 Status: dzVents: Error (2.4.6): ...pi/domoticz/scripts/dzVents/generated_scripts/MI Day.lua:9: attempt to compare number with table
Status: dzVents: Info: ------ Finished MI Day[/code]
You are trying to evaluate the table containing all attributes of your lux device. You should only evaluate the lux value.
Change
to
if (domoticz.devices('Lux').lux >= 3701 ) then
Melotron
Post by Melotron »
waaren wrote: Monday 13 August 2018 9:28
Change
to
Thank you so much its working perfectly now =))
