433Mhz Touch Remote -> Sonoff RF Bridge -> Domoticz
Posted: Tuesday 07 August 2018 19:56
Hi all, I am planning to install some Sonoff Wifi switches and smart plugs in a room of my apartment. My initial idea was to control them using these 433Mhz wireless touch remotes which look like ordinary wall switches -
https://www.aliexpress.com/item/Vhome-W ... 4c4dcWQeNJ
Ideally these switches will send signals to a Sonoff RF bridge which will then communicate them to Domoticz via MQTT over wifi. In that way I can easily assign each wireless touch remote to a one or a group of devices in Domoticz.
I flashed the Sonoff RF bridge with the latest Tasmota firmware 6.1.1. The wireless remote switches were also all successfully learnt by the Sonoff RF bridge. When buttons on the remote were pressed. I could see MQTT messages in the console associated with those button. The problems I am facing now are:
1. The MQTT messages from the RF bridge were not seen in Domoticz. I gathered that this is due to the Sonoff RF bridge MQTT message format not being recognized by Domoticz? A Tasmota firmware modification is needed?
2. Assuming the previous problem was solved. How do I setup Domoticz such that a button press on the wireless remote toggles the state of a device, group, and scene?
I seem to get the feeling that the feature I mentioned is simply not possible with the current Tasmota firmware. Most questions on the forum talked about linking sensors via the RF bridge to Domotizc (kind or a similar to what I want to do here) or Domoticz controlling 433Mhz devices via the RF bridge.
Thank you.
Unfortunately I cannot provide any screenshots of the MQTT messages from the RF bridge. After a failed OTA update, my Sonoff RF bridge is completely dead. Even a direct flashing via a USB to serial connection didn't work. I have ordered a few more, should be here in a week or two...
Thank you.
