Hey Folks,
For some reason sending battery level to a switch or selector switch in Domoticz via MQTT does not work.
In the below example (link) I am able to control the device but the battery level is simply ignored.
viewtopic.php?f=68&t=23607&start=20#p188171
I am sending it as: msg.payload.Battery
Any help would be appreciated, with Zigbee2MQTT it will be necessary for many devices to have battery levels via MQTT.
Cheers
MQTT Battery Level Not Working
ben53252642
ben53252642
Re: MQTT Battery Level Not Working
Anyone?
I've spent about 5 hours trying to get a battery level entered into a device via MQTT without success, it IS possible with JSON.
Seems to me MQTT is lagging behind the JSON interface.
- jvdz
- Domoticz version: 4.107
Replied to your github post, but I am pretty sure the "switchlight" mqtt command doesn't interpret the battery variable and you need to change it to "udevice" command as shown in my answer in github.
Jos
Jos
ben53252642
Problem solved thanks to jvdz example.
https://github.com/domoticz/domoticz/issues/2618
What to send via MQTT to Domoticz (in this case to a selector switch).
Tested example in Node-Red for Xiaomi WXKG01LM Button
Selector switch levels:
10 single
20 double
30 long
msg.payload.idx = 1213 ;
msg.payload.nvalue = 2 ;
msg.payload.level = level;
msg.payload.svalue = level.toString();
msg.payload.Battery = batt;
[{"id":"2419ca7a.aa80e6","type":"mqtt in","z":"f962b96d.7044c8","name":"zigbee2mqtt/out","topic":"zigbee2mqtt/xiaomitestbutton","qos":"2","broker":"7e7eab95.c38d54","x":340,"y":440,"wires":[["9c57d2e1.13bc1"]]},{"id":"9c57d2e1.13bc1","type":"json","z":"f962b96d.7044c8","name":"","property":"payload","action":"","pretty":false,"x":490,"y":440,"wires":[["b3d3900.fbcbf7"]]},{"id":"26f6b6a1.ff999a","type":"mqtt out","z":"f962b96d.7044c8","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"5e06ebd0.e4e9d4","x":790,"y":440,"wires":[]},{"id":"b3d3900.fbcbf7","type":"function","z":"f962b96d.7044c8","name":"Format Data","func":"// Xiaomi WXKG01LM Button\nvar click = msg.payload.click.toString();\nvar batt = Math.round(msg.payload.battery);\nmsg.payload.idx = 1217 ;\nif(click == 'single') {\n var level = 10\n} else if (click == 'double') {\n var level = 20\n// Action holding button before release (not used)\n//} else if (click == 'long') {\n// var level = 20\n} else if (click == 'long_release') {\n var level = 30\n}\nmsg.payload.nvalue = 2 ;\nmsg.payload.level = level;\nmsg.payload.svalue = level.toString();\nmsg.payload.Battery = batt;\nreturn msg;","outputs":1,"noerr":0,"x":630,"y":440,"wires":[["26f6b6a1.ff999a","5fa57f09.6d0fe"]]},{"id":"7e7eab95.c38d54","type":"mqtt-broker","z":"","name":"Zigbee","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"domoticz/bridge/state","birthQos":"0","birthPayload":"online","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"5e06ebd0.e4e9d4","type":"mqtt-broker","z":"","name":"Domoticz","broker":"192.168.0.5","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]10 single
20 double
30 long
Tnx.
It works for me too now.
It's strange that "Battery" seems to be case-sensitive, everything else is lowercase.
- sincze
- Domoticz version: 2024.4
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
