Voltage monitor with ESP8266
Posted: Thursday 02 August 2018 20:51
by MartHale
Using a voltage divider I was able to make a voltage monitor with the ESP8266, with ADS1115.
The Outback charge controller was a real pain to give me the voltage in any form that I could use with Domoticz, but now I have a complete status even on my cell phone. I love this program, combined with Espeasy.!!!!
Re: Voltage monitor with ESP8266
Posted: Thursday 02 August 2018 20:53
by MartHale
The only issue I get is I get an value of -65 V on like a random basis. I am guessing this is cause by flyback voltage to the battery, but I am not sure how to filter that out, but I can manually remove the data points with the shift click on the graft. I love searching these forums
Posted: Sunday 05 August 2018 11:32
by sincze
Nice one
A solution to your problem would be to store the values first in a dummy esp device. (not sending them to domoticz directly) Using rules to see if it has a 'valid' number and then post to domoticz.
https://www.letscontrolit.com/wiki/inde ... rial_Rules
Posted: Sunday 05 August 2018 20:34
by MartHale
I like that solution, I like that alot!
Rules on the ESP8266 board, would filter any bad data before it would be recorded and thus there would be no problem data, only missing gaps.
I guess the next trick is to switch to the ESP32 so that I can use the sleep mode to save power so I can run this on batteries. Ideally, I would like sensors that are powered by an lithium battery which in turn are charged by a solar panel.
Posted: Sunday 05 August 2018 21:57
by sincze
Just let me know if you need help
I know it works.
Next to data validation I now only send data if the data itself was changed since the last reading. And use timers as well. To look at the data every X seconds.
Posted: Monday 06 August 2018 21:02
by MartHale
So I guess what you do is disable "enabled" on the device, then create a loop with timers so that it reads the data compares with last then sends via rules.
I took a quick look at rules, but I did not see where they detailed how to send the data to domoticzs.....
If you have a link to an example that would be cool
Posted: Monday 06 August 2018 21:09
by sincze
MartHale wrote: Monday 06 August 2018 21:02
Leave the device enabled but disable only the 'send to controller' check box, where the IDX is filled.
To send data from rules you can use
SendToHTTP 192.168.1.111,8080,/json.htm?type=command¶m=udevice&idx=<IDXHERE>&nvalue=0&svalue=<YOUR VALUE>
Start your rules with:
On System#Boot do
TimerSet,1,30
EndOn
This will create a timer that will go off every 30 seconds! Don't forget to enable NTP as well!
Posted: Thursday 04 October 2018 0:47
by MartHale
Posted: Friday 05 October 2018 15:51
by sincze
Exellent, but still a question
We love pictures of succesful and less succesful projects for inspiration.
Posted: Sunday 07 October 2018 14:33
by MartHale
https://www.youtube.com/watch?v=WytU5uj ... 6w&index=2
I have been trying to understand capacitors magic in circuits, this video was most eye opening..
Posted: Sunday 07 October 2018 20:42
by MartHale
I did make a video of the progress so far ->
https://www.youtube.com/watch?v=rpFmTUszNPI
