Z-Wave update problem on 4.9701 stable
Posted: Tuesday 31 July 2018 15:28
by febalci
Using Ubuntu 18.04, Domoticz 4.9701 Stable...
Since i upgraded Domoticz stable to 4,9701 I have this weird update problems on ZWave roller shutters. Using qubino flush roller shutters.
As you can see below, the "Sinema Panjuru" roller shutter is physically closed, It writes "Closed" on the button, but the slide is not reflecting that it is closed. Btw, all shutters are "Blind Percentage Inverted". In ozw control panel Node 17 is "Off". This problem is not only with the Node 17, it changes within the day, other nodes behave erratically as well. Although the control panel and button text and icon shows "Closed", the slider shows that it is open. Also, when i query json values, the "Sinema Panjuru" Status is "Closed" however the Level and LevelInt values are "99", whereas they should be "0" for Closed roller shutters. Is this a problem with ozw or domoticz or my hardware?
Re: Z-Wave update problem on 4.9701 stable
Posted: Monday 03 September 2018 14:01
by rsm1024
I have the same problem
i using raspberry pi 3b+, with razberry 2 z-wave, and fibaro FGRM.
have you found the solution ?
Posted: Monday 03 September 2018 14:17
by febalci
Unfortunately not, still having the same problem.
