With nodered you can use the published events from MQTT by setting the topic to domoticz/out.
Then you need a function node to filter what event you like to control. I use extensive Nodered flows to control several devices.
Here is a flow to start how you could collect data from MQTT with domoticz/out
[{"id":"cd222b8e.945fb8","type":"mqtt in","z":"150731a6.9b7e5e","name":"MQTT","topic":"domoticz/out","qos":"1","broker":"fc68fc78.a14ae","x":150,"y":260,"wires":[["cbef9f4a.ea47d"]]},{"id":"cbef9f4a.ea47d","type":"json","z":"150731a6.9b7e5e","name":"","property":"payload","action":"","pretty":false,"x":290,"y":260,"wires":[["70c33c55.72fb64","b259e07.59b2a2","b6de791b.57af08","eebb88a4.b5a368"]]},{"id":"b259e07.59b2a2","type":"switch","z":"150731a6.9b7e5e","name":"stype","property":"payload.stype","propertyType":"msg","rules":[{"t":"eq","v":"kWh","vt":"str"},{"t":"eq","v":"LaCrosse TX3","vt":"str"},{"t":"eq","v":"Sound Level","vt":"str"},{"t":"eq","v":"Weather Station","vt":"str"},{"t":"eq","v":"Electric","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":450,"y":260,"wires":[["a7edc925.0e8878"],["69f16424.05c39c"],["862d4453.3427f8"],["e8720982.29a618","69f16424.05c39c"],["a7edc925.0e8878"]]},{"id":"fc68fc78.a14ae","type":"mqtt-broker","z":"","name":"","broker":"192.168.178.188","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Here is a flow to send data to MQTT
[{"id":"de09d7bd.29a8e8","type":"inject","z":"75ec7863.1959e8","name":"","topic":"light","payload":"Off","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":280,"wires":[["2f822c74.4153d4"]]},{"id":"21317f95.a289c","type":"inject","z":"75ec7863.1959e8","name":"","topic":"light","payload":"On","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":240,"wires":[["2f822c74.4153d4"]]},{"id":"fa3a4b82.b07b88","type":"function","z":"75ec7863.1959e8","name":"","func":"var mqtt = { command: \"setcolbrightnessvalue\", idx: 59, hex: msg.payload, brightness: 90, iswhite: false };\n\nvar newMsg = {};\nnewMsg.payload = {};\nnewMsg.payload = mqtt;\nreturn newMsg\n","outputs":1,"noerr":0,"x":410,"y":120,"wires":[["3c7b98c0.c99a28","b170a429.7792e8"]]},{"id":"3c7b98c0.c99a28","type":"mqtt out","z":"75ec7863.1959e8","name":"","topic":"domoticz/in","qos":"1","retain":"true","broker":"fc68fc78.a14ae","x":710,"y":120,"wires":[]},{"id":"b170a429.7792e8","type":"debug","z":"75ec7863.1959e8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":690,"y":260,"wires":[]},{"id":"2f822c74.4153d4","type":"function","z":"75ec7863.1959e8","name":"","func":"// 59 is a RGB strip, 28 is a normal ligth\nif (msg.topic==\"rgb\"){\n var mqtt = { command: \"switchlight\", idx: 59, switchcmd: msg.payload };\n} else if (msg.topic==\"light\"){\n var mqtt={ command: \"switchlight\", idx: 28, switchcmd: msg.payload }\n}\n\nvar newMsg = {};\nnewMsg.payload = {};\nnewMsg.payload = mqtt;\nreturn newMsg\n","outputs":1,"noerr":0,"x":410,"y":260,"wires":[["3c7b98c0.c99a28","b170a429.7792e8"]]},{"id":"38d76626.40560a","type":"inject","z":"75ec7863.1959e8","name":"set color","topic":"","payload":"FF0B85","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":60,"wires":[["fa3a4b82.b07b88"]]},{"id":"5e1d95e8.8198ac","type":"inject","z":"75ec7863.1959e8","name":"","topic":"rgb","payload":"Off","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":140,"wires":[["2f822c74.4153d4"]]},{"id":"dbea6765.a9ad18","type":"inject","z":"75ec7863.1959e8","name":"","topic":"rgb","payload":"On","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":100,"wires":[["2f822c74.4153d4"]]},{"id":"fc68fc78.a14ae","type":"mqtt-broker","z":"","name":"","broker":"192.168.178.188","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
If you want to collect your uservariables this flow could be a start. I use it to set timers for lights, wakeup alarm and rollershutters.
[{"id":"43534cff.c597d4","type":"inject","z":"65fdffa8.dd87d","name":"","topic":"button","payload":"17","payloadType":"num","repeat":"60","crontab":"","once":true,"onceDelay":"1","x":110,"y":240,"wires":[["595da7f.2494358"]]},{"id":"595da7f.2494358","type":"http request","z":"65fdffa8.dd87d","name":"","method":"GET","ret":"obj","url":"http://192.168.178.188:8088/json.htm?param=getuservariables&type=command","tls":"","x":270,"y":240,"wires":[["c8ac953a.354328"]]},{"id":"c8ac953a.354328","type":"function","z":"65fdffa8.dd87d","name":"Select the vars","func":"//loop the payload we don't need all\nfor (var i=0;i<msg.payload.result.length;i++){\n //set the received minutes to 24h time format\n var newMins = parseInt(msg.payload.result[i].Value);\n var cMins=newMins;\n var newHrs=Math.floor(newMins/60);\n // the number of hours is too big set it to 7 hours\n if (newHrs>23){newHrs=7}\n newMins = newMins - (60 * newHrs)\n // 12:34 \n newTime=(newHrs<10?\"0\":'') + newHrs + \":\" +(newMins<10?\"0\":'') + newMins\n //extract the name\n var tmpName = msg.payload.result[i].Name\n if (tmpName==\"LichtWoonkamer\" ||\n tmpName==\"LichtSlaapkamer\" ||\n tmpName==\"Wekker\" ||\n tmpName==\"RolluikOpenSlaapkamer\" ||\n tmpName==\"LichtKeuken\" ||\n tmpName==\"LichtBuiten\" ||\n tmpName==\"RolluikOpenLogeer\" ||\n tmpName==\"RolluikKantoor\") {\n \n // now send them one by one \n newMsg={payload: newTime, topic:tmpName, cMin:cMins}\n node.send(newMsg)\n \n \n }\n}","outputs":1,"noerr":0,"x":440,"y":240,"wires":[["49a6afb7.ff702"]]},{"id":"49a6afb7.ff702","type":"switch","z":"65fdffa8.dd87d","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"LichtWoonkamer","vt":"str"},{"t":"eq","v":"LichtSlaapkamer","vt":"str"},{"t":"eq","v":"Wekker","vt":"str"},{"t":"eq","v":"RolluikOpenSlaapkamer","vt":"str"},{"t":"eq","v":"LichtKeuken","vt":"str"},{"t":"eq","v":"LichtBuiten","vt":"str"},{"t":"eq","v":"RolluikOpenLogeer","vt":"str"},{"t":"eq","v":"RolluikKantoor","vt":"str"}],"checkall":"true","repair":false,"outputs":8,"x":590,"y":240,"wires":[["5f26157.dd391ec","2efab279.5e1a9e"],["50904e59.f0861"],["6b809640.6800a8"],["d377196b.ce7c48"],["9d3a9264.a1b11"],["c10b99b3.986f18"],["2dbe37eb.a28cb8"],["c117573d.c1b348"]]}]
My Domoticz, MQTT and Nodered are all on the same Raspberry PI 3+ (Nodered and MQTT are password protected)
