Faro Barcelona Fan control with RFXCom in Domoticz
Posted: Saturday 21 July 2018 19:26
by gamel53
It is the first posting for me on this forum. My apolagies if I make some mistake by posting my question right here
My configuration:
- Domoticz on Raspberry3
- RFXCOM RFXtrx433 USB 433.92MHz
- Faro Barcelona fan/light with UC7076R receiver and UC7080T remote (433MHz)
- Chacon switches
The fan remote is working on 433MHz. By looking on the web, I found out that the receiver reference was also used by Lucci fans (https://www.beaconlightingtradeclub.com ... -2013_.pdf), so I was hoping that Lucci Air protocol would work. Initially, it was not. I contacted RFXCOM and they provided me right away with a new firmware (Version: Pro1/1016) and now I am able to manually control my fan after configuring a new switch as described below:
viewtopic.php?t=15499
I had then a new switch ('Ventilateur Chambre') that I can control on the Domoticz interface:
So it was quite a good progress, but the whole point of integrating the fan in Domoticz was to allow a Chacon switch to control the light.
I tried using a blocky scheme or a lua script but was not able to make it work.
Here below the script I tried:
if (devicechanged['Plafonnier Chambre Switch'] == 'On') then
    print ("Device based event fired on 'Plafonnier Chambre Switch', value '"..tostring(devicechanged['Plafonnier Chambre Switch']).."'");
    commandArray['Ventilateur Chambre']='Light'
    print(commandArray['Ventilateur Chambre'])
elseif (devicechanged['Plafonnier Chambre Switch'] == 'Off') then
And I got the following result in the logs but nothing happened to the light:
2018-07-21 19:21:59.262 (RFXtrx433) Lighting 2 (Plafonnier Chambre Switch)
2018-07-21 19:21:59.291 (RFXtrx433) Fan (Ventilateur Chambre)
2018-07-21 19:21:59.268 Status: LUA: Device based event fired on 'Plafonnier Chambre Switch', value 'On'
2018-07-21 19:21:59.268 Status: LUA: Light
2018-07-21 19:21:59.274 Status: EventSystem: Script event triggered: Chambre Toggle
But unfortunatly, nothing happens, whereas when I push the "Light" button of the fan in Domoticz, it works.
Maybe I am missing something.
Thanks you very much for your help.
Regards.
Re: Faro Barcelona Fan control with RFXCom in Domoticz
Posted: Sunday 22 July 2018 18:22
by gamel53
I am answering to my own question, as I spent a bit more time to solve it.
I figured out that the problem was a case problem: Unlike the labels shown in the picture, each command should be lower case: 'off'', 'low', 'med', 'hi', 'light'. With these modifications, my scripts are working.
The last issue I have is that the fan commands are not display on the map. It is seen as an 'On/Off' switch by Domoticz. Not a bit issue for me.
Posted: Thursday 11 June 2020 20:08
by danielccm
I'm getting the Faro Lantau fan... It's arriving on Monday... I'm guessing your work will be applicable? 😅
Thanks!!!
Posted: Monday 15 June 2020 22:39
by clemzclemz
Hello gamel53,
I purchased a Faro Lantau G fan, without light. And so far I cannot set it up in Domoticz, as the link to the thread is dead : https://www.domoticz.com/forum/viewtopic.php?t=15499
Could you post another setup to get the fan setting to work (low, medium, high and off) ? Great work if you succeeded to do that 8-)
Posted: Wednesday 24 June 2020 0:43
by danielccm
clemzclemz wrote: Monday 15 June 2020 22:39 Hello gamel53,
Did you get around to setting it up in Domoticz? If so, how? I have just installed the fan... and it works with the remote.. but I can't get it to work with Domoticz....
Posted: Sunday 28 June 2020 19:36
by danielccm
I have been able to get the fan's buttons (the remotes's buttons at least) identified in Domoticz.. but as a ByronSX chime on/off switch... I have DM setup in a Synology 918+ NAS.... How can I change the identification to whatever is needed for them to work? I can't get them to work correctly... :-(
