Concatenating an URL with values from sensors.
Posted: Wednesday 11 July 2018 7:32
by radiochild
Hi, I am running Domoticzs on a Synology NAS and I am trying to send a value to an ESPEasy LED display. I can send the dummy info, just as a straight number, e.g.
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'..333 }
but I can't substitute a sensor value for the number, e.g.
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'..sensortemp}
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'..['Sensor_Temperature']}
The errors usually relate to concatenation a global or things like that.
I don't understand the examples and other posts I have read. Can someone please explain if this can work or how to do it if it can't?
Re: Concatenating an URL with values from sensors.
Posted: Wednesday 11 July 2018 9:33
by waaren
radiochild wrote: Wednesday 11 July 2018 7:32
Yes it can work. If you post the complete script it is easier to comment on what modifications are needed to get this to work.
Posted: Wednesday 11 July 2018 12:13
by radiochild
Hi Waaren, thanks for having a look for me.
-- Variables
baseurlESPEasy = "http://192.168.1.xx/control?cmd="
if devicechanged['Undercot_Temperature'] then
This works.
I just can't figure out how to put a value from a sensor where the '333' is.
Posted: Wednesday 11 July 2018 12:56
by waaren
radiochild wrote: Wednesday 11 July 2018 12:13
-- Variables
This works.
This will send the same as in your example with the temperature from sensor Undercot_Temperature. (dzVents)
-- Send Undercot Temp
on = { devices = { "Undercot_Temperature" }},
logging = { level = domoticz.LOG_DEBUG,
marker = "Send undercot" },
execute = function(domoticz, undercot )
local baseurlESPEasy = "http://192.168.1.xx/control?cmd="
domoticz.openURL({
url = baseurlESPEasy .. "7dt" .. undercot.temperature,
method = "GET"
Posted: Wednesday 11 July 2018 13:29
by radiochild
Hi Waaren.
I tried your code and I get;
Error: EventSystem: in Portable LED Display: [string "-- Send Undercot Temp ..."]:6: attempt to index global 'domoticz' (a nil value)
I am using this in Events. I realise I didn't mention that before, does that make a difference?
Posted: Wednesday 11 July 2018 13:37
by jvdz
So you have an LUA event script and you want to send the new received value for ... to ESPEASY....right?
Something like this should be close for a Device Lua event script:
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'.. devicechanged['Undercot_Temperature']}
.. but are you sure about that ESPEASY URL? Does that work directly from a browser?
Jos
Posted: Wednesday 11 July 2018 13:46
by radiochild
Hi jvdz,
Thank you! That worked a charm. The url works in a browser for ESPEasy. It now works in Domoticz. It's just an update to a MAX7219 LED display. So simple but I just couldn't figureit out.
Thank you again, Waaren and jvdz for helping me out.
Posted: Wednesday 11 July 2018 17:19
by waaren
radiochild wrote: Wednesday 11 July 2018 13:29
Hi Waaren.
Hi radioChild, my script is dzVents. Choose dzVents in the event editor and copy paste the script ..
Posted: Wednesday 19 February 2020 6:56
by MarloCZ
Hello, please can someone advise me, I try the script written above, but my display shows nothing.
When I enter a command via URL, it will show up on the display.
Thanks for the help
on = { devices = { "Outdoor_thermometer" }},
local baseurlESPEasy = "http://192.168.7.71/control?cmd="
domoticz.openURL({
url = baseurlESPEasy .. "7dt" .. Outdoor_thermometer,
method = "GET"
Device:
48 Dummy 14080 1 Outdoor_thermometer Temp LaCrosse TX3 2.7 C
LOG:
2020-02-19 06:57:59.694 Status: dzVents: Error (2.4.19): Send undercot: An error occured when calling event handler Displej-1
2020-02-19 06:57:59.694 Status: dzVents: Error (2.4.19): Send undercot: ...Domoticz\scripts\dzVents\generated_scripts/Displej-1.lua:13: attempt to concatenate global 'Outdoor_thermometer' (a nil value)
2020-02-19 06:57:59.694 Status: dzVents: Info: Send undercot: ------ Finished Displej-1
2020-02-19 06:58:02.679 EventSystem: Event triggered: Termostat-Loznice_2
Posted: Wednesday 19 February 2020 8:38
by waaren
MarloCZ wrote: Wednesday 19 February 2020 6:56
You copied and paste some unexpected values.
Can you try this
-- Send temperature of a sensor to ESP Easy
return
on =
devices =
'Outdoor_thermometer',
logging =
marker = 'Temperature to ESPEasy'
execute = function(dz, item)
local ESPEasyURL = 'http://192.168.7.71/control?cmd='
dz.openURL(
url = ESPEasyURL .. '7dt,' .. item.temperature,
method = 'GET',
Posted: Wednesday 19 February 2020 13:07
by MarloCZ
Thank you very much for the modified script.
I turned it on, but the screen still doesn't show me anything
The extract from the log is as follows:
2020-02-19 13:06:25.489 Status: dzVents: Info: Handling events for: "Outdoor_thermometer", value: "5.06"
2020-02-19 13:06:25.490 Status: dzVents: Info: Temperature to ESPEasy: ------ Start internal script: Display-1: Device: "Outdoor_thermometer (Dummy)", Index: 48
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: url = http://192.168.7.71/control?cmd=7dt5.0599999427795
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: method = GET
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: post data = nil
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: headers = nil
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: callback = nil
2020-02-19 13:06:25.491 Status: dzVents: Info: Temperature to ESPEasy: ------ Finished Display-1
Posted: Wednesday 19 February 2020 13:22
by MarloCZ
So I figured it out - it works
There was no comma in 7dt
Can I have another request, could it be done on the display alternate between two different temperatures - from outside and from inside thermometer - alternately ?
Thank you in advance for your help.
Posted: Wednesday 19 February 2020 14:43
by waaren
MarloCZ wrote: Wednesday 19 February 2020 13:22
Could be something like
-- Send temperature of two sensors alternately to ESP Easy
return
on =
timer =
'every minute',
logging =
local display
if dz.time.minutes % 2 == 0 then
display = dz.utils.round(dz.devices('Outdoor_thermometer').temperature,1)
display = dz.utils.round(dz.devices('Indoor_thermometer').temperature,1)
dz.openURL(
url = ESPEasyURL .. '7dt,' .. display
method = 'GET',
Posted: Wednesday 19 February 2020 21:43
by MarloCZ
Thanks for the new script, but it reports me an error
2020-02-19 21:36:57.915 Status: dzVents: Error (2.4.19): error loading module 'Display-2' from file 'C:\Program Files (x86)\Domoticz\scripts\dzVents\generated_scripts/Display-2.lua':
2020-02-19 21:36:57.915 ...Domoticz\scripts\dzVents\generated_scripts/Display-2.lua:32: '}' expected (to close '{' at line 30) near 'method'
Posted: Wednesday 19 February 2020 23:07
by waaren
MarloCZ wrote: Wednesday 19 February 2020 21:43
Sorry for that. I missed a comma after display.
can you try again ?
return
on =
timer =
'every minute',
logging =
local display
dz.openURL(
url = ESPEasyURL .. '7dt,' .. display,
method = 'GET',
Posted: Thursday 20 February 2020 7:07
by MarloCZ
Thank you, it works very well.
I have one more request, is somehow done to change temperatures not after one minute, but after 5 (10) seconds
Thank you
Posted: Thursday 20 February 2020 14:58
by waaren
MarloCZ wrote: Thursday 20 February 2020 7:07
Thank you
That's possible with the attached script. Please note that the temperature shown can be 50 seconds behind measured temperature. It is possible to have a real-time temperature with a different approach but that would require dzVents >= 3.0.0
-- Send temperature of two sensors alternately to ESP Easy every 10 seconds
local scriptVar = 'Temperature to ESPEasy'
return
on =
timer =
'every minute',
logging =
marker = scriptVar,
local display = {}
display[0] = dz.utils.round(dz.devices('Outdoor_thermometer').temperature,1)
display[1] = dz.utils.round(dz.devices('Indoor_thermometer').temperature,1)
local function sendTemp(selector)
temperature = display[selector % 2]
dz.openURL(
url = ESPEasyURL .. '7dt,' .. temperature,
method = 'GET',
}).afterSec(selector * 10)
-- main
for i = 0, 5 do
sendTemp(i)
Posted: Thursday 20 February 2020 17:37
by MarloCZ
Thank you very much, it works great.
Posted: Thursday 20 February 2020 17:44
by waaren
MarloCZ wrote: Thursday 20 February 2020 17:37
Show us a picture please ?
Posted: Friday 21 February 2020 15:48
by MarloCZ
Picture of what? A picture of the display?
I am currently testing two adults, 7 numbers and 4 numbers.
https://uloz.to/file/Up42O3LzfwyK/2020- ... -40-50-jpg
