Has anyone got Energenie modules (ENER002-4) working?
Posted: Saturday 03 May 2014 11:07
by darrenjgo
https://energenie4u.co.uk/index.php/cat ... /ENER002-4
I can't see any events from the remote or the sockets.
Any tips, tricks or confirmation that they aren't yet compatible, would be much appreciated.
Cheers.
Darren
Re: Has anyone got Energenie modules (ENER002-4) working?
Posted: Saturday 03 May 2014 11:53
by b_weijenberg
Energenie remotes are not received (see chapter 2.2 in the RFXtrx User Guide.
Is it possible to learn an ID in the module using RFXmngr with the Type selection Energenie or Energenie5 on the Lighting1 tab?
Posted: Sunday 04 May 2014 13:19
by darrenjgo
Thanks for reply.
Yeah, saw the note about the remotes, but thought I might be able to still send a command to the modules.
I went through all of the options using RFXmngr using Energenie or Energenie5 on the Lighting1 tab, but the module never switches on.
The modules are quite common, so I suspect someone has been through this already.
Posted: Friday 09 May 2014 14:51
by darrenjgo
I've since swapped the ENER002-4 modules for an ENER010, because the ENER010 is noted as definitely being supported.
It's still not working though.
I see nothing when using RFXmngr.
Can anyone with an ENER010 give me an idea of how they managed to use Domoticz to control the sockets?
Posted: Friday 09 May 2014 16:09
by b_weijenberg
You will not see anything in RFXmngr as the energenie is not received!
You can control the Energenie in Lighting1 in RFXmngr and learn this as a remote in the Energenie
Posted: Friday 09 May 2014 17:18
by darrenjgo
I've managed to get this working now with both the ENER002-4 and ENER010 products.
I knew the events from the remote control would not be seen, so I went through the RFXmngr options, trying to transmit all Energenie and Energenie5 house codes and all unit numbers in the hope to get a reaction from the sockets.
I then chose to put the module into learn mode before transmitting anything, and found that whatever House/Unit codes I transmitted would then be learnt by the module, and it would link itself to that code.
In the process, I also learnt that choosing Type 'Energenie' = Product ENER010 & ENER002-4, whereas Type 'Energenie5' = 'Energenie 5-gang module'.
I then moved back to Domoticz, added a manual Light/Switch and set it to 'Energenie', House Code A, Unit Code 1, then put the ENER010 into learn mode, and pressed the Test button in Domoticz. This attached the ENER010 to House Code A, and I could control socket 1. I just needed to add three more switches to accommodate sockets A2/A3/A4.
Same process for the ENER002-4 modules, but as each one is individual, I just needed to use learn mode on one at a time. The advantage here, is that I have the option to put more than one in learn mode then transmit a single set of codes if I wish to 'pair' them up.
Posted: Friday 15 January 2016 21:45
by sion
Hi.
I am trying to get these to work myself, but with no luck at the moment.
Do I actually need to do anything in the Rfx manager?
I have tried in do motifs : ad manual switch, put modual in learn mode, then press test.
But not getting anywhere.
Thanks.
