Directory with persistent data cleanup?  [Solved]
cincuranet
Post by cincuranet »
Hi, I noticed that the data directory, where the persistent data is stored, is not cleaned up when I delete the script. Is this expected? And is there a better solution to clean this up except "manually" matching script names and "data" names (I don't want to delete data files for scripts in use, to not loose data)?
Re: Directory with persistent data cleanup?  [Solved]
There is no mechanism in domoticz or dzVents to do this automatically but if you want do it programmatic you could use this small bash script
# bash script to remove dzVents datafiles orphans
domoticzdir="/opt/domoticz"                   # Change to reflect your domoticz base directory
cd $domoticzdir/scripts/dzVents/data
for filename in *.lua; do
    scriptfile=$(echo "../scripts/"$filename | sed -e   's/__data_//g')
    if [ ! -f "$scriptfile" ] ;then
        echo "$scriptfile not found!"
        ls -l $filename                               # should not show a recent date
        echo sudo rm -f $filename             # remove the echo once convinced it will do the job expected
    fi
done
cincuranet
Yes, that's basically what I do. Thanks.
