Xiaomi Dafang camera view problem
satanasinc
Domoticz version: 4.9700
Post by satanasinc »
Hi!
First of all excuse my bad english.
I added my Xiaomi Dafang Camera with DafangHack firmware to my domoticz and it worked for a couple of months.
Now can´t see the camera in the domoticcz windows but the connection test apears to be fine and displays the camera.
Someone knows what can be happen?
Thanks in advance for your help.
Regards.
satanasinc
Re: Xiaomi Dafang camera view problem
Hi!
Resolved.
Edit and coment o remove these lines in /system/sdcard/config/lighttpd.conf
$HTTP["scheme"] == "http" {
# capture vhost name with regex conditiona -> %0 in redirect pattern
# must be the most inner block to the redirect rule
$HTTP["host"] =~ ".*" {
url.redirect = (".*" => "https://%0$0")
This disable the https redirection.
mozo78
Post by mozo78 »
Thank you! It worked for me as well!
Ouate
Post by Ouate »
I have the same problem (preview of camera is working but nothing when I click the photo button).
How to edit the file lighttpd.conf (as described above) ? in SSH ?
Does someone can help me please?
Ouate
Post by Ouate »
Ouate wrote: Monday 04 March 2019 16:20 Hi,
nobody ? :|
Shirley54
Post by Shirley54 »
I think I am also facing this issue. Did you get any proper solution?
Eravinera
Post by Eravinera »
I have a similar problem, but the proposed option does not help
qerryp
Post by qerryp »
I had the same issue with my Samsung galaxy S10 which I had to troubleshoot from https://uaetechnician.ae/samsung-service-centre and in case of xiaomi go to the xda developer where they release the update on weekly basis.
Derik
Post by Derik »
some solutions.
My dafang are stil dark to..
When i follw thew ikie should be simple.
Ony no camera in Domoticz
https://www.domoticz.com/wiki/Xiaomi_Camera
