Measure water tank volume with flow sensor
Posted: Monday 18 June 2018 9:21
by olleman
Hi!
I'm looking into a nice project for my boat where I'd like to monitor the volume in my water tank that holds 100l. Ideally I would like to present this as "how many litres are left in the tank" and I would also need someway to "fill" the tank virtually. Is this possible in domoticz or can anyone recommend anything else?
Edit Using an incremental counter would be a way to go but I need a way to reset it every time I "fill" the tank. I can't find any way to reset an incremental counter. Is it even doable, perhaps with LUA?
I will be sending the data from a 8266 device.
,Olle
Re: Measure water tank volume with flow sensor
Posted: Monday 18 June 2018 16:05
by SweetPants
How do you measure the water level in the tank?
If you measure it 'actively' there is no need to reset a counter
Using the HC-SR04 can give you the information, but it is not waterproof.
Posted: Monday 18 June 2018 16:20
by olleman
SweetPants wrote: Monday 18 June 2018 16:05
Posted: Monday 18 June 2018 21:28
by olleman
I will meassure it by subtracting the value reported from the water flow sensor from a utillity sensor, or at least, that's what I'm aiming for.
Posted: Monday 18 June 2018 21:34
by SweetPants
olleman wrote: Monday 18 June 2018 21:28
But then you still don't know when the water tank is full, only by manual update. You can do that with a dummy push button and using persistent data and dzVentz
Posted: Tuesday 19 June 2018 12:01
by olleman
SweetPants wrote: Monday 18 June 2018 21:34
Sounds exactly like what I want but I have no idea howto move along with persistent data and events. Some start up help would be much appreciated:)
Posted: Tuesday 19 June 2018 14:58
by SweetPants
Take a look at the dzVentz wiki.
https://www.domoticz.com/wiki/DzVents:_ ... _scripting it explains the use of persistent data.
Posted: Wednesday 20 June 2018 7:23
by olleman
Thankyou, I had a look and I'm afraid that's way out of my league to do on my own. Would anyone be interested in getting me started?
Posted: Thursday 21 June 2018 11:27
by olleman
I've done some more research into this and I assume that this would be a way to do it (bare in mind, I have never scripted or worked with Lua before).
1. Store every reading in volume from flow sensor (the sensor wull actually report a volume counted for a specified amount of time) in a variable with a historic data table.
2. Make calculations of the sum of each value in the table and when it reaches, for example 25 litres. Set a dummy sensor with percentage to 75% To indicate that the tank now is 75% full.
3. Repeat step 2 but with 50l/50%, 75l/25% and 100l/0% (since my tank holds roughly 100l)
4. When virtual switch "filled my water tank" is switched on (will automaticly switch off again after 3 seconds). Erase all data in the table, set dummy percentage sensor to 100% and start from step 1 again.
Is this what you had in mind? I really don't know how to put all this together though...
Posted: Sunday 24 June 2018 8:27
by olleman
After A LOT of trial and error I think I've come up with something that actually works. The code is most likely real uggly but it seems to be working. Tought I would share it.
- Spoiler: show
- return {
active = true,
devices = {'WaterUsage', 'Filled Watertank'}
data = {
vatten = { history = true, maxItems = 10000 }
execute = function(domoticz, sensor)
-- Lägg till WaterUsage om den varit > 0
if domoticz.devices('WaterUsage').WhActual > 0 then
domoticz.data.vatten.add(sensor.WhActual)
if domoticz.devices('Filled Watertank').state == 'On' then
domoticz.data.vatten.reset(sensor.WhActual)
domoticz.devices('Vattentank').updatePercentage(100)
-- sum
local sum = domoticz.data.vatten.sum()
--Ändra vattentankens fyllnadsgrad i % beroende på summan i historiken för WaterUsageen
if (sum > 5) and (sum < 15) then
domoticz.devices('Vattentank').updatePercentage(90)
elseif (sum > 15) and (sum < 25) then
domoticz.devices('Vattentank').updatePercentage(80)
elseif (sum > 25) and (sum < 35) then
domoticz.devices('Vattentank').updatePercentage(70)
elseif (sum > 35) and (sum < 45) then
domoticz.devices('Vattentank').updatePercentage(60)
elseif (sum > 45) and (sum < 55) then
domoticz.devices('Vattentank').updatePercentage(50)
elseif (sum > 55) and (sum < 65) then
domoticz.devices('Vattentank').updatePercentage(40)
elseif (sum > 65) and (sum < 75) then
domoticz.devices('Vattentank').updatePercentage(30)
elseif (sum > 75) and (sum < 85) then
domoticz.devices('Vattentank').updatePercentage(20)
elseif (sum > 85) and (sum < 90) then
domoticz.devices('Vattentank').updatePercentage(10)
elseif (sum >= 90) and (sum <= 90.99) then
domoticz.devices('Vattentank').updatePercentage(9)
elseif (sum >= 91) and (sum <= 91.99) then
domoticz.devices('Vattentank').updatePercentage(8)
elseif (sum >= 92) and (sum <= 92.99) then
domoticz.devices('Vattentank').updatePercentage(7)
elseif (sum >= 93) and (sum <= 93.99) then
domoticz.devices('Vattentank').updatePercentage(6)
elseif (sum >= 94) and (sum <= 94.99) then
domoticz.devices('Vattentank').updatePercentage(5)
elseif (sum >= 95) and (sum <= 95.99) then
domoticz.devices('Vattentank').updatePercentage(4)
elseif (sum >= 96) and (sum <= 96.99) then
domoticz.devices('Vattentank').updatePercentage(3)
elseif (sum >= 97) and (sum <= 97.99) then
domoticz.devices('Vattentank').updatePercentage(2)
elseif (sum >= 98) and (sum <= 98.99) then
domoticz.devices('Vattentank').updatePercentage(1)
elseif (sum >= 99) then
domoticz.devices('Vattentank').updatePercentage(0)
