problem in the logfile
Posted: Saturday 16 June 2018 12:44
hello,
i have an error in the logfile and i cant explain where its from, i googled it a lot but no answers found yet.
every 5 minutes the next problem is in the logfile:
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('313', '0')") : database disk image is malformed
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('314', '0')") : database disk image is malformed
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('3268', '50')") : database disk image is malformed
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('3269', '0')") : database disk image is malformed
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('3273', '0')") : database disk image is malformed
2018-06-16 12:40:00.500 Error: SQL Query("DELETE FROM Percentage WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')") : database disk image is malformed
