How compile/get Luasocket to work on FreeBSD with Domoticz
Whiskey
Post by Whiskey »
I am trying to get the Hue status check script to work on FreeBSD for which I need LuaSocket. The Philips Hue wiki page refers to another wiki page that details how to install luasocket library files that have been precompiled for the Pi. Those don't work on FreeBSD :( And neither does the FreeBSD package of LuaSocket.
So I've cloned the LuaSocket repository and managed to get it to compile against Lua in domoticz, but it fails to load the module with
Error: EventSystem: in /usr/home/domoticz/domoticz/scripts/lua/script_time_checkLights.lua: error loading module 'socket.core' from file '/usr/local/lib/lua/5.2/socket/core.so':
2018-06-10 14:05:00.013 /usr/local/lib/lua/5.2/socket/core.so: Undefined symbol "lua_gettop"
I've been searching for a while and have not found a way to fix this. I did find this issue and this page that both say to use "-Wl,-E" parameters when building lua:
In UNIX, you can use the dynamic or the static libraries. But when using the static libraries remember to include the parameter "-Wl,-E" in Linux to make the application exports the Lua functions, so the loaded modules are not dependent on the LuaBinaries dynamic libraries.
So I tried adding that to lua/src/CMakeLists.txt:
IF(${CMAKE_SYSTEM_NAME} MATCHES "Linux|FreeBSD")
        SET(OperatingSystem "Linux")
        SET(COMMON_LDFLAGS "${COMMON_LDFLAGS} -Wl,-E")
        add_definitions(-DLUA_USE_LINUX)
ENDIF(${CMAKE_SYSTEM_NAME} MATCHES "Linux|FreeBSD")
And for compiling luasocket I only changed the option in src/makefile that specifies where the Lua headers are kept:
LUAINC_freebsd?=/home/domoticz/domoticz/lua/src/
But no luck :cry:
I've been stuck for days trying to get this to work, so any pointers are much appreciated.
Derik
Re: How compile/get Luasocket to work on FreeBSD with Domoticz
Post by Derik »
He the same issue here, on ubuntu lts 18.04
Perhaps found a solution?
pagocs
Post by pagocs »
If you still have the issue check this discussion and the possible solution: https://github.com/domoticz/domoticz/issues/3216
