No neutral light switches
miroslavpetrov
Post by miroslavpetrov »
I am looking for a cheap no neutral light switch. I have tried the xiaomi aquara wall switch, but in my country the wall boxes are circular not rectangular as in China which makes the installation difficult.
Can you suggest a similar wall switch but for EU junction box or a module such as Fibaro Dimmer 2, but cheaper?
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
gijsje
Domoticz version: Stable
Re: No neutral light switches
Post by gijsje »
If you have a 433mHz capability you can use the awmt-003 it is powered by a battry and you connected to the switch that you have in the wall
https://www.toolstation.nl/shop/Electri ... 67?lnjs=en
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
