IFTTT spams my Domoticz Topic is solved
drwurn
Post by drwurn »
I've setup a simple ifttt. When connected to a certain wifi network, a http is send with webhooks.
The code that I use is:
http://<LOGIN>:<PW>@<IP>:8080/json.htm?type=command&param=switchlight&idx=25&switchcmd=Toggle
The result is that my Domoticz is getting spammed with requests.
The log from my virtual switch is:
2018-06-11 11:56:00 Off
2018-06-11 11:56:00 On
2018-06-11 11:55:59 Off
2018-06-11 11:55:59 On
When I replace Toggle with On/Off the log result is multiple on/off in a row.
And when I look in the IFTTT app, it ran like 10 times or so, but it sends multiple requests every second.
How to fix this?
DutchHans
Re: IFTTT spams my Domoticz
Post by DutchHans »
You're probably not connected all the time.. when walking around you're connection may drop for a second which results in a trigger 'toggle'.. and then connect again which also results in a toggle...
.how does your ifttt 'this' look?...
Hope this helps
drwurn
Post by drwurn »
When I look in my IFTTT it says it ran the script like 10 times.
My log is about 1500 pages in less then an hour.
drwurn
Post by drwurn »
The this is "android device" and then "connects to a specific wifi network"
drwurn
Post by drwurn »
Fixed by leaving the fields "on action/off action"
So far this presence method works good with no false switches.
Need more testing and also going to test on Iphone.
