dzVents and Onkyo hardware
Posted: Sunday 10 June 2018 10:15
by Varazir
Hello
I use this script to turn on my Onkyo if the tv is on.
https://gist.github.com/varazir/6246d4c ... 61dd4d0d5c
It's copy paste script so much is just taken from other scripts.
I use the hardware OnkyoAVTCP for controlling my Onkyo, the problem I'm having is it tries to connect every 30 sec
so after the Onkyo is turned on I have to wait up to 30 until I can control it. Is there a way to get around that ?
Force connect or something ?
TIA
Daniel
Re: dzVents and Onkyo hardware
Posted: Sunday 10 June 2018 23:41
by jake
What about the existing Onkyo python plugin? You have instant control over your whole receiver, since the plugin catches all information that the receiver broadcasts (source/listening mode/volume/on-off).
Posted: Monday 11 June 2018 20:14
by Varazir
jake wrote: Sunday 10 June 2018 23:41
I keep getting this
https://gist.github.com/varazir/ebb2d68 ... dfac83df6f
Posted: Monday 11 June 2018 20:56
by jake
Do youpossibly have an unsupported type of receiver?
When I enable the Onkyo hardware again, it gives this log:
2018-06-11 20:50:08.667 (Onkyo AV Receiver TX-NR535) Receiver found:
2018-06-11 20:50:08.667 (Onkyo AV Receiver TX-NR535) Type: AV Receiver or Stereo Receiver
2018-06-11 20:50:08.667 (Onkyo AV Receiver TX-NR535) Type: TX-NR535
2018-06-11 20:50:08.667 (Onkyo AV Receiver TX-NR535) Region: European or Asian model
2018-06-11 20:50:08.667 (Onkyo AV Receiver TX-NR535) IP adress: 192.168.1.33
2018-06-11 20:50:08.667 (Onkyo AV Receiver TX-NR535) eISCP port: 60128
2018-06-11 20:50:08.667 (Onkyo AV Receiver TX-NR535) MAC: 0009B0973A25
2018-06-11 20:50:10.626 (Onkyo AV Receiver TX-NR535) Requesting XML configuration
2018-06-11 20:50:10.777 (Onkyo AV Receiver TX-NR535) Received XML
2018-06-11 20:50:12.636 (Onkyo AV Receiver TX-NR535) Checking if Devices exist
2018-06-11 20:50:12.636 (Onkyo AV Receiver TX-NR535) Checking Main zone
2018-06-11 20:50:12.636 (Onkyo AV Receiver TX-NR535) Receiver main power device exists
2018-06-11 20:50:12.636 (Onkyo AV Receiver TX-NR535) Receiver input selector device exists
2018-06-11 20:50:12.636 (Onkyo AV Receiver TX-NR535) Receiver listening mode selector device exists
2018-06-11 20:50:12.636 (Onkyo AV Receiver TX-NR535) Receiver Tuner preset selector device exists
2018-06-11 20:50:12.637 (Onkyo AV Receiver TX-NR535) Receiver volume control device exists
2018-06-11 20:50:12.637 (Onkyo AV Receiver TX-NR535) Checking Zone 2
2018-06-11 20:50:12.637 (Onkyo AV Receiver TX-NR535) Receiver Zone 2 power device exists
2018-06-11 20:50:12.637 (Onkyo AV Receiver TX-NR535) Receiver input selector Zone 2 device exists
2018-06-11 20:50:12.637 (Onkyo AV Receiver TX-NR535) Receiver zone 2 volume control device exists
2018-06-11 20:50:13.140 (Onkyo AV Receiver TX-NR535) Update 0:'Off' (Onkyo AV Receiver TX-NR535 Power)
Are you sure you use this plugin:
https://github.com/jorgh6/domoticz-onkyo-plugin
Posted: Monday 11 June 2018 21:41
by Varazir
I have a Onkyo TX-NR509, don't think it's supported.
The build in works but the delay sux.
Posted: Tuesday 12 June 2018 18:17
by jake
I saw that you already mentioned your receiver number in the Onkyo Python topic.
Please check with the dev if he will continue his ideas with the xml file. Offering help and input usually helps
