(SOLVED) Use of lua sets (dictionary) in dzVents persistent data
Posted: Saturday 09 June 2018 10:28
by popoff1998
I have a script that need to control internally the state of some dummy devices and store it on persisten data. In lua I can do this:
In the dzVents script I use code like this:
And in some part of my execute funtion I do (boton is the device passed as argument to execute funtion:
Of course boton.name can be 'COMPLETO', 'CESPED' or 'GOTEOS'.
This gives me the following error:
dzVents: Error (2.4.6): MYDEBUG: ...moticz/scripts/dzVents/generated_scripts/GrupoRiegos.lua:106: attempt to index field 'estado' (a nil value)
It isn't possible to use sets in persistent data in dzVents?
Here is the complete code of the script:
estado = {['COMPLETO'] = false, ['CESPED'] = true, ['GOTEOS'] = false }
print(estado['CESPED'])
trueCode: Select all
data = {
estado = {['COMPLETO'] = false, ['CESPED'] = false, ['GOTEOS'] = false }
},Code: Select all
domoticz.data.estado[boton.name] = trueThis gives me the following error:
- Spoiler: show
-- Variables de control nriegosCESPED = 4 nriegosGOTEOS = 4 abreGeneral = false -- Funciones local function RiegaCesped(domoticz,delay,tRiego) domoticz.devices('EV-TURBINAS').switchOn().afterMin(delay).forMin(tRiego) domoticz.devices('EV-PORCHE').switchOn().afterMin(tRiego + delay).forMin(tRiego) domoticz.devices('EV-CUARTILLO').switchOn().afterMin(2*tRiego + delay).forMin(tRiego) domoticz.devices('EV-PIEDRAS').switchOn().afterMin(3*tRiego + delay).forMin(tRiego) end local function RiegaGoteos(domoticz,delay,tRiego,tPatio) domoticz.devices('EV-GOTEOBAJO').switchOn().afterMin(delay).forMin(tRiego) domoticz.devices('EV-GOTEOALTO').switchOn().afterMin(tRiego + delay).forMin(tRiego) domoticz.devices('EV-GOTEOOLIVO').switchOn().afterMin(2*tRiego + delay).forMin(tRiego) domoticz.devices('EV-PATIO').switchOn().afterMin(3*tRiego + delay).forMin(tPatio) end local function TerminaCesped(domoticz) domoticz.devices('EV-TURBINAS').switchOff() domoticz.devices('EV-PORCHE').switchOff() domoticz.devices('EV-CUARTILLO').switchOff() domoticz.devices('EV-PIEDRAS').switchOff() end local function TerminaGoteos(domoticz) domoticz.devices('EV-GOTEOBAJO').switchOff() domoticz.devices('EV-GOTEOALTO').switchOff() domoticz.devices('EV-GOTEOOLIVO').switchOff() domoticz.devices('EV-PATIO').switchOff() end local function AbreGeneral(domoticz,tiempo) if(abreGeneral) then domoticz.devices('EV-GENERAL').switchOn().forMin(tiempo) end end -- Programa principal return { active = true, on = { devices = { 'COMPLETO', 'CESPED', 'GOTEOS' } }, logging = { level = domoticz.LOG_DEBUG, marker = "MYDEBUG" }, data = { -- semaforo controlara si se esta regando en un riego de grupo semaforo = { initial = false }, -- offInterno conrolara si ha sido el propio script quien ha apagado el boton offInterno = { initial = false }, -- Almacenará el contador de agua al comenzar el riego contadorInicial = { initial = 0 }, -- Tabla de estados de los botones estado = {['COMPLETO'] = false, ['CESPED'] = false, ['GOTEOS'] = false } }, execute = function(domoticz,boton) tRiego = domoticz.variables('TIEMPO-RIEGO').value tPatio = domoticz.variables('PATIO-RIEGO').value -- EL BOTON SE ENCIENDE -- Antes que nada deshabilitamos los dobles clicks de botones de grupos if(boton.state == 'On' and domoticz.data.semaforo) then -- Mandamos la notificacion domoticz.notify('RIEGOERROR','*Riego ' .. boton.name .. ' no activado por bloqueo de semaforo*',domoticz.PRIORITY_HIGH) domoticz.data.offInterno = true boton.switchOff() elseif(boton.state == 'On') then -- Mandamos la notificacion domoticz.notify('RIEGOON','*Riego ' .. boton.name .. ' comenzado*',domoticz.PRIORITY_HIGH) -- Habilitamos el semaforo domoticz.data.semaforo = true -- Cambiamos su estado domoticz.data.estado[boton.name] = true -- Leemos el contador domoticz.data.contadorInicial = domoticz.devices('CONTADOR AGUA').counter domoticz.log('CONTADOR: ' .. domoticz.data.contadorInicial,domoticz.LOG_FORCE) -- Operamos segun el boton pulsado if(boton.name == 'COMPLETO') then AbreGeneral(domoticz,(nriegosCESPED + nriegosGOTEOS) * tRiego) RiegaCesped(domoticz,0,tRiego) RiegaGoteos(domoticz,nriegosCESPED * tRiego,tRiego,tPatio) boton.switchOff().afterMin((nriegosCESPED + nriegosGOTEOS) * tRiego) elseif(boton.name == 'CESPED') then AbreGeneral(domoticz,nriegosCESPED * tRiego) RiegaCesped(domoticz,0,tRiego) boton.switchOff().afterMin(nriegosCESPED * tRiego) elseif(boton.name == 'GOTEOS') then AbreGeneral(domoticz,nriegosGOTEOS * tRiego) RiegaGoteos(domoticz,0,tRiego,tPatio) boton.switchOff().afterMin(nriegosGOTEOS * tRiego) end end -- EL BOTON SE APAGA if(boton.state == 'Off') then domoticz.log('DEVICE: ' .. boton.name .. ' Estados: ' .. tostring(domoticz.data.estado['COMPLETO']) .. ' ' .. tostring(domoticz.data.estado['CESPED']) .. ' ' .. tostring(domoticz.data.estado['GOTEOS']) , domoticz.LOG_FORCE) if(domoticz.data.offInterno) then -- El off se ha producido por un doble click y lo ignoramos domoticz.data.offInterno = false -- PROBLEMA: Aqui vamos a llegar tanto por el apagado a mano como por el apagado por el temporizador -- Hay que evitar que si llegamos por el temporizador de alguno que se apago a mano -- se cumpla la condicion ya que semaforo pertenece a otro boton distinto. Voy a hacer una comprobacion ... --elseif(domoticz.data.semaforo) then elseif(domoticz.data.estado[boton.name]) then -- Se ha producido el off y estabamos regando -- Mandamos el mensaje del consumo local consumo = domoticz.devices('CONTADOR AGUA').counter - domoticz.data.contadorInicial domoticz.notify('CONSUMO','*Consumidos ' .. consumo .. ' m3*',domoticz.PRIORITY_LOW) -- Mandamos la notificacion domoticz.notify('RIEGOFF','*Riego ' .. boton.name .. ' terminado*',domoticz.PRIORITY_HIGH) -- Deshabilitamos el semaforo domoticz.data.semaforo = false -- Cambiamos su estado domoticz.data.estado[boton.name] = false -- Paramos el/los riegos domoticz.devices('EV-GENERAL').switchOff() if(boton.name == 'COMPLETO') then TerminaCesped(domoticz) TerminaGoteos(domoticz) elseif(boton.name == 'CESPED') then TerminaCesped(domoticz) elseif(boton.name == 'GOTEOS') then TerminaGoteos(domoticz) end end -- Si no se ha cumplido ninguna de las dos anteriores no hacemos nada -- pues el off se ha producido por el temporizador que se puso en el on. end end }
