Page 1 of 2
Did I leave the door open?
Posted: Friday 08 June 2018 15:15
by felix63
A DzVents script to check to see if doors have been left open for too long. Both the number of doors and the threshold for reporting on a door are easily changed my adjusting the values in the table at the beginning of the script. The table 'devicesToCheck' needs to contain the exact names of your door switches. To prevent you going nuts the warnings will stop once the amounts of warning per door exceeds the variable alerCount.
local devicesToCheck = {
-- table with doors to check and the minutes before the first warning is given
{ ['name'] = 'Voordeur', ['threshold'] = 3 },
{ ['name'] = 'Garagedeur', ['threshold'] = 10 },
{ ['name'] = 'Achterdeur', ['threshold'] = 3 },
{ ['name'] = 'Provisiekast deur', ['threshold'] = 10 },
{ ['name'] = 'Bergingdeur', ['threshold'] = 10 },
-- number of times you are warned about an open door
local alertCount = 3
active = true,
timer = {'every 5 minutes'},
logging = {
-- level = domoticz.LOG_INFO,
marker = "POR"
-- count per door of the number of alerts per door
data = {
['Voordeur'] = {initial=0},
['Garagedeur'] = {initial=0},
['Achterdeur'] = {initial=0},
['Provisiekast deur'] = {initial=0},
['Bergingdeur'] = {initial=0},
execute = function(domoticz)
for i, deviceToCheck in pairs(devicesToCheck) do
local name = deviceToCheck['name']
local threshold = deviceToCheck['threshold']
local state = domoticz.devices(name).state
local minutes = domoticz.devices(name).lastUpdate.minutesAgo
if ( state == 'Open') then
domoticz.log('Device ' .. name .. ' staat ' .. minutes .. ' minuten open.')
if (minutes > threshold) and (domoticz.data[name] < alertCount) then
domoticz.data[name] = domoticz.data[name] + 1
domoticz.notify('Device ' .. name .. ' staat al langer dan ' .. minutes .. ' minuten open.', domoticz.PRIORITY_HIGH)
domoticz.log('dit is waarschuwing #' .. tostring(domoticz.data[name]))
elseif (domoticz.data[name] > 0) then
domoticz.notify('Device ' .. name .. ' is weer gesloten.', domoticz.PRIORITY_HIGH)
domoticz.log('Device ' .. name .. ' is ' .. minutes .. ' dicht.')
domoticz.data[name] = 0
Re: Did I leave the door open?
Posted: Sunday 08 July 2018 12:59
by felix63
Updated the script above to give a notification if the door is closed again....
Posted: Thursday 02 August 2018 20:13
by hoeby
I used your nice script.
But on the first try it didn't work.
I am using telegram for notification. When the IF = TRUE, i only got a "1" in the telegram message.
Therefor i changed your script to this
if (minutes > threshold) then
domoticz.notify('Herinnering-open',
domoticz.log('dit is waarschuwing ' .. tostring(domoticz.data[name]))
domoticz.notify('Herinnering-dicht',
What changed?:
I added
'Herinnering-open', and
'Herinnering-dicht', to the notify message.
Personal thing, i removed the devices tekst in de notify script, this had nothing to do with the problem i noticed.
Don't know if this adding gives problems to other notification options. But on telegram this works, now i nicely get
"name .. ' staat al langer dan ' .. minutes .. ' minuten open. or
Posted: Friday 24 August 2018 15:15
by vwtune
Thanks for your script.
only the alertcount don't work. if i change the number in 4, 5 or whatever, it still gives me more messages that the door is open, till i close the door, then the alerts stopts. What is wrong with the script?
Posted: Monday 26 November 2018 13:19
by TheJuice
Works like a charm, thanks.
I wonder if it would be easy to add an array of actions to take for each door when they are open for too long and are closed again.
For instance :
- If the entrance door is open for too long, send an alert.
- If the terrace door is open for too long, turn off the heating, and turn it on again once the door gets closed again...
Cheers
Posted: Monday 26 November 2018 16:09
by hoeby
Add the code rules, unter the "THEN" word. And fill in the "Another switch" to the switch that needs to be controlled
Hope you get it to work, otherwise post it, then i will try to help.
domoticz.devices('Another switch').switchOn()
or
domoticz.devices('Another switch').switchOff()
Posted: Monday 26 November 2018 18:00
by TheJuice
I know how I could do it dirty in the "then" part of the if(), but I would have to test for each type of device :
if (device == "Entrance door") {
elseif (device == "Terrace door") {
send Notification
But I wanted to know if I could do something like that :
actions = {
['Entrance door'] = {domoticz.devices('Another switch').switchOn()},
['Terrace door'] = {send Notification},
And then :
domoticz.actions[name].apllyAction...
Do you think it's feasible ?
Posted: Monday 26 November 2018 20:58
by waaren
TheJuice wrote: Monday 26 November 2018 18:00
send Notification
actions = {
And then :
Yes, this is possible. You can add a function to a Lua table and call that function just like any other function.
Posted: Tuesday 27 November 2018 8:53
by TheJuice
Thanks, I'll dig a little deeper
Posted: Tuesday 27 November 2018 10:24
by waaren
TheJuice wrote: Tuesday 27 November 2018 8:53
Send you a PM
Posted: Wednesday 27 February 2019 19:25
by remko2000
I used this script also:
{ ['name'] = 'Voordeur', ['threshold'] = 10 },
{ ['name'] = 'Garage', ['threshold'] = 10 },
{ ['name'] = 'Achterdeur', ['threshold'] = 10 },
active = true,
logging = {
marker = "POR"
data = {
['Garage'] = {initial=0},
Works fine, only problem is that ' alerCount' won't work. I keep receiving messages. How do I adjust this?
Posted: Wednesday 27 February 2019 23:08
by felix63
Did you try running the script with logging turned on? I have the very same script still running. It stops notifying me when alertcount has been reached. Could it be that there is something wrong with the data variables used for keeping track of the number of alerts? Do the variables in the data section have identical names as the names of the doors being tested?
Otherwise, send me the script as you are running it.
Cheers
Posted: Thursday 28 February 2019 10:17
by remko2000
This is my code:
{ ['name'] = 'Garage', ['threshold'] = 2 },
active = true,
logging = {
marker = "POR"
data = {
Works great. I get every 5 minutes a message from Prowl.
Problem is: it doesn't stop. I think 3 messages is enough.
What do you mean with
The doornames are corresponding. Do I have to add somewhere else variables?
Posted: Thursday 28 February 2019 11:48
by TheJuice
In my case, notifications stop after the threshhold has been reached...
Posted: Thursday 28 February 2019 19:46
by remko2000
yes but in my case not. Why doesn't work the threshold in my case. What can be the problem?
Posted: Friday 01 March 2019 0:00
by felix63
I suppose something goes wrong with your data variable. Otherwise I can not explain the inconsistent behavior where it works fine for some users but not for you. Do you use other scripts that use persistent data?
Did you run with logging enabled? Uncomment the line
and please post the lines from your log marked with ‘POR’.
What hardware are you running on?
Posted: Friday 01 March 2019 0:01
by felix63
TheJuice wrote: Thursday 28 February 2019 11:48
Btw did you adapt the script with variable action stored in tables as you mentioned couple of posts back?
Posted: Friday 01 March 2019 15:25
by remko2000
Or right. I uncommand the log.
If I see the log in domoticz with "POR" with the door open (cold
)I get this:
2019-03-01 15:10:00.534 Status: dzVents: Info: POR: ------ Start internal script: Deuren open test2:, trigger: every 5 minutes
2019-03-01 15:10:00.573 Status: dzVents: Info: POR: Device Garage staat 28 minuten open.
2019-03-01 15:10:00.574 Status: dzVents: Info: POR: dit is waarschuwing 9
2019-03-01 15:10:00.577 Status: dzVents: Info: POR: ------ Finished Deuren open test2
2019-03-01 15:15:00.138 Status: dzVents: Info: POR: ------ Start internal script: Deuren open test2:, trigger: every 5 minutes
2019-03-01 15:15:00.158 Status: dzVents: Info: POR: Device Garage staat 33 minuten open.
2019-03-01 15:15:00.158 Status: dzVents: Info: POR: dit is waarschuwing 10
2019-03-01 15:15:00.160 Status: dzVents: Info: POR: ------ Finished Deuren open test2
2019-03-01 15:20:00.259 Status: dzVents: Info: POR: ------ Start internal script: Deuren open test2:, trigger: every 5 minutes
2019-03-01 15:20:00.278 Status: dzVents: Info: POR: Device Garage staat 38 minuten open.
2019-03-01 15:20:00.278 Status: dzVents: Info: POR: dit is waarschuwing 11
2019-03-01 15:20:00.280 Status: dzVents: Info: POR: ------ Finished Deuren open test2
It looks like the timer don't work.But I don't understand why.
My hardware is a raspberry 3 master en a raspberry 3 slave with a zwavecontroller (with doorcontacts). The slave send the status of my doors to my master. On the master I run this script.
What do you mean? The script a copied earlier is the script I use.
Posted: Friday 01 March 2019 20:48
by felix63
One can easily overlook the obvious. Change the line that reads:
to
if (minutes > threshold) and (Domoticz.data[name] < alertCount) then
And your problem will be solved!
Posted: Saturday 02 March 2019 18:16
by remko2000
I changed this rule. My code is now:
active = true,
logging = {
marker = "POR"
data = {
Now I get only one messages (garages is closed) an after this nothing more (the door was closed).
