Switch UI is not updating after a command is sent
Posted: Thursday 07 June 2018 22:23
Just managed to get Domoticz up and running on Linux (Ubuntu 1804). It all seems to be working well, however there is one wrinkle.
If I go to the switches tab an turn a light off. It says switching off and the light goes off, however the item does not change. The icon stays with the lamp looking on and if I click it again rather than switching on it will again say Switching off. If I refresh the page the switch comes up with the expected off icon and from here the reverse happens I can switch it on but not off again.
I have tried turning it off and waiting for an update however it never updates.
I have also turned it off then swapped to Dashboard/tab and back to switches tab (which is extremly rapid) at which point everything is updated and I can turn it on again.
Because of the speed of the redraw of tabs etc. it feels like this could be some form of misconfiguration. Has anyone ever seen it before?
