Page 1 of 2
Virtual sensor for rain
Posted: Sunday 03 June 2018 8:40
by packetloss
Afternoon!
I followed this page: https://www.domoticz.com/wiki/Virtual_w ... 29_Devices for creating a virtual device for the rain in mm that I get from Weather Underground. The page says "Mission completed, the virtual temperature sensor can now be used in events."
I do have a value for the rain:
but now I see in Blocky, this is not working yet :( .
Anybody has a solution for this? What I want to do is start my GR105 (*) device or not, on set times like the evening, depending if there was rain in the last 12 hours or not.
(*) https://www.domotique-store.fr/2416-thi ... e-tour.jpg
Re: Virtual sensor for rain
Posted: Sunday 03 June 2018 11:56
by gizmocuz
It's very unclear what you want to do... first of, WU is native supported in domoticz, you do not need a script for this
You want to control 'somethings' when there was more then 'xx' mm of rain ?
Posted: Sunday 03 June 2018 12:08
by packetloss
correct, I know Weather Underground is supported, that's why I have the devices like temp, humidti, rain etc.
yes. I want to enable / disable devices like the GR105 or any other thing supported in Domoticz, after like 8mm of rain. It seems that Blocky doesn't work with devices like weather measurement. Thats what I understand from "NOT WORKING YET".
Posted: Sunday 03 June 2018 12:28
by gizmocuz
Blockly works with temperature devices, not sure about rain or wind, it should not be that difficult to add, but time is my problem
Posted: Sunday 03 June 2018 12:48
by packetloss
gizmocuz wrote: Sunday 03 June 2018 12:28 Blockly works with temperature devices, not sure about rain or wind, it should not be that difficult to add, but time is my problem
Yes, when I remove my rain device (IDX256) and replace it with a temperature device, there's no warning of NOT WORKING YET.
Ok, I understand you're the maintainer / programmer of this part of Blocky in Domoticz?
If you can implement this in Blocky, yes please! In a simplified form, this is what I do with Lua:
local idxr = 256
if devicechanged[sensorwu] then
        sWeatherFirst, sWeatherRain = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+)")
        sWeatherRain = tonumber(sWeatherRain)
        print('sWeatherRain is now' .. sWeatherRain)
        commandArray['UpdateDevice']=idxr .. '|0|' .. sWeatherRain      -- for updating Dummy devices e.g. '96|0|Hello World'
and this works: I see the correct value of IDX # 256 when I go to Setup, Events, Show current values. And this is Devices:
What is not working, is this (IDX256) item in Weather
but I don't mind that. I want to use it in Blocky please.
Posted: Sunday 03 June 2018 13:29
by gizmocuz
That is probably because you use the wrong amount of parameters for the device
See the Wiki/JSON what values a rain sensor should have (https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s)
But again, if you just add the normal WU hardware (no script what so every), and i could make it (not today i think) that in blockly you can use
if (myrain>10mm) then....
Then you could work with this ?
Since you are 'programming' in lua, you might want to have a look in the javascript/cpp code if you want it implemented fast
Posted: Sunday 03 June 2018 16:49
by packetloss
gizmocuz wrote: Sunday 03 June 2018 13:29 That is probably because you use the wrong amount of parameters for the device See the Wiki/JSON what values a rain sensor should have (https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s)
I will have a look at that.
gizmocuz wrote: Sunday 03 June 2018 13:29But again, if you just add the normal WU hardware (no script what so every),
I do that. Just so you know, this one is working perfect:
So I do have a working WU hardware setup. The only thing I want extra is an item/device with the rain in mm *only*.
Thats what I do, the normal WU hardware. The only addition (so not instead of) is what I read on https://www.domoticz.com/wiki/Virtual_w ... emperature
gizmocuz wrote: Sunday 03 June 2018 13:29 and i could make it (not today i think) that in blockly you can use if (myrain>10mm) then.... Then you could work with this ?
correct! Thank you.
Posted: Monday 04 June 2018 7:58
by gizmocuz
I had a look.... (quick look)
In the next beta i remove the 'NOT WORKING YET', as a lot (if not all) weather sensors are supported
In blockly, with the rain sensor, it checks if the "amount of rain in the last hour",
if (rain>10) means, if there was more then 10mm of rain in the last hour, then do something
if you want to work with the total rain for a day, in your lua script, you have to use this table:
otherdevices_rain
otherdevices_rain_lasthour
I'm no lua developer, but our wiki helps.
Another option is to use dzVents
Posted: Monday 04 June 2018 20:13
by packetloss
gizmocuz wrote: Monday 04 June 2018 7:58 I had a look.... (quick look) In the next beta i remove the 'NOT WORKING YET', as a lot (if not all) weather sensors are supported
Ok, thank you! I keep an eye on the beta updates.
I'm not using Lua for my sprinklers, only Blocky. Do I understand correctly, in Blocky I can only use the last hour, not the last 12 or 24 hours?
Posted: Monday 04 June 2018 21:48
by packetloss
I installed the update ( Compile Date: 2018-06-04 08:19:42 Version: 3.9571) and indeed, the "NOT WORKING YET" is removed. Unfortunately, my Blocky is not working yet. Can you please have look, whats going wrong?
The script:
and the value:
and the syslog output:
Jun  4 21:47:00 domoticz: EventSystem: Lua script error (Blockly), Name: sprinkler_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare nil with number
Posted: Monday 04 June 2018 22:04
by packetloss
O and by the way, this one is working;
So I conclude that the problem is with the WeatherData-Rain-IDX256 <= 1 item.
Posted: Monday 04 June 2018 22:41
by Simania
I'm looking for exactly the same.
If my rainsensor has a certain amount of rain (better to say a lack of it) for the past 24 hours, then turn on a Z-wave switch, which controls the valve for my sprinkler.
Lots of thanks in advance!
Posted: Tuesday 05 June 2018 7:36
by gizmocuz
@simania, the 'compare' value for the rain sensor is the amount of rain for the last hour already
@both, i would say, start simple, make a blockly that just 'prints' the value.
For example, create a dummy rain sensor, and a blockly like:
On the 'devices' page you see the index value of the rain sensor (idx) like 1103.
Rain1
Rain1
note that in the log message, weatherdevice[1103] = rain_rate and when you use raindevice[1103] it is total_rain of today
When you now update the virtual rain sensor with
http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=1103&nvalue=0&svalue=2;1000
It should print in the log:
2018-06-05 07:26:09.292 Status: Rain from last hour is: 0.02
If we want to do something when there is more then 5mm of rain in the last hour we could make a blockly like:
Rain2
Rain2
and update the virtual sensor with:
http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=1103&nvalue=0&svalue=510;1081
the first part (before the ; is the rain_rate in 0.01mm, 510 = 5.1mm, the last part is the counter (always increasing) in mm
so if the first example (2;1000) was more then 5 minutes ago, you should now have two values in the database (log) after 5 minutes, 1000 and 1081, 1081-1000=81mm of rain today
How to use the total rain today in an action is for part 2
Posted: Tuesday 05 June 2018 8:05
by gizmocuz
Using total rain for today in an action:
For this we are going to use dzVents, it is in the same editor as Blockly, but then choose dzVents
We are going to (Always!!) start simple, then build the final script, so lets start with printing the values:
		devices = {
			'DumRain'
		domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
		domoticz.log('rain_rate: ' .. device.rainRate, domoticz.LOG_INFO)
		domoticz.log('total_rain: ' .. device.rain, domoticz.LOG_INFO)
When we now execute the json query:
it will output in the log:
2018-06-05 07:48:07.545 Status: dzVents: Info: Handling events for: "DumRain", value: "511;1081"
2018-06-05 07:48:07.545 Status: dzVents: Info: ------ Start internal script: TestTotalRain: Device: "DumRain (Dummy)", Index: 1103
2018-06-05 07:48:07.546 Status: dzVents: Info: Device DumRain was changed
2018-06-05 07:48:07.547 Status: dzVents: Info: rain_rate: 5.1100001335144
2018-06-05 07:48:07.547 Status: dzVents: Info: total_rain: 81
2018-06-05 07:48:07.547 Status: dzVents: Info: ------ Finished TestTotalRain
Perfect! all the values we need... now lets switch on a light when there is to much rainfall today (>80mm)
For this i added a dummy switch called 'MyDummySwitch'
Here is the new script:
		devices = {
			'DumRain'
		local my_light = domoticz.devices('MyDummySwitch')
		if (device.rain>80) then
            domoticz.log('more then 80mm of rain today!!', domoticz.LOG_INFO)
	        my_light.switchOn()
	        my_light.switchOff()
Now of course, on every rain change the light will be switched on/off, and probably you would not want this, so there are several options to prevent this, so lets do a simple one:
		devices = {
			'DumRain'
        	local bTurnOn = false
        	    bTurnOn = true;
        	if (my_light.bState ~= bTurnOn) then
		            if (bTurnOn == true) then
		                domoticz.log('switching light ON', domoticz.LOG_INFO)
			         my_light.switchOn()
		                domoticz.log('switching light OFF', domoticz.LOG_INFO)
In the installation folder of domoticz there is a folder 'dzVents' with documentation, and also a scripts/dzVents/examples
Posted: Tuesday 05 June 2018 21:39
by Simania
@gizmocuz wow what a detailed and quick response! I really appreciate this!
I will try both methods to see what is best fit and will let you know of the outcome.
Once again, your time is much appreciated.
Posted: Tuesday 12 June 2018 17:14
by Simania
Gizmocus,
The first example works perfectly, but the second, with DzVents not.
If I execute the json query, in my example my ip is 192.168.178.98 and the id of the 'DumRain' device is 162:
http://192.168.178.98:8080/json.htm?typ ... e=580;2024
I get the following output, the name of the event is 'Sproeien':
2018-06-12 17:01:12.665 Status: dzVents: Info: Handling events for: "DumRain", value: "510;1081"
2018-06-12 17:01:12.665 Status: dzVents: Info: ------ Start internal script: Sproeien: Device: "DumRain (WeatherData)", Index: 162
2018-06-12 17:01:12.665 Status: dzVents: Info: ------ Finished Sproeien
Somehow no values show up, where as in the first example evverything works like it should, see my ouput:
2018-06-12 16:55:49.339 Status: Too much rain this last hour!! (5.1)
Any thought?
Here is the event I copied from this thread:
		devices = {
			'DumRain'
Regards,
Simania
Posted: Tuesday 12 June 2018 17:48
by waaren
the --[[ means the start of a multiline comment
the ]] means the end of a multiline comment
the -- means the start of a single line comment
so effectively everything between --[[
and
including the entire line after ]]-- is not interpreted as code by Lua / dzVents.
This should work
		devices = {
			'DumRain'
Posted: Wednesday 13 June 2018 10:10
by Simania
Thanks waaren, I'm pretty new to this dzVents coding stuff.
It works now btw.
Posted: Wednesday 13 June 2018 15:12
by Simania
Okey I used the following code in dzVents together with my Netatmo rainsensor:
      timer = { 'every minute' },
	execute = function(domoticz, timer)
	local netatmo_rain = domoticz.devices(23)
		domoticz.log('rain_rate: ' .. netatmo_rain.rainRate, domoticz.LOG_INFO)
		domoticz.log('total_rain: ' .. netatmo_rain.rain, domoticz.LOG_INFO)
And it gives met the following output in the log:
2018-06-13 15:07:00.253 Status: dzVents: Info: ------ Start internal script: Netatmo:, trigger: every minute
2018-06-13 15:07:00.276 Status: dzVents: Info: rain_rate: 0
2018-06-13 15:07:00.276 Status: dzVents: Info: total_rain: 0.10000000149012
2018-06-13 15:07:00.276 Status: dzVents: Info: ------ Finished Netatmo
I find it kind of strange that I get a trillion digit number for the total_rain. Is it possible to use it like this with my Netatmo rainsensor, or is this number just something different?
Regards in advance!
Posted: Thursday 14 June 2018 7:09
by gizmocuz
@Simania, this is a float representation, it is safe to use it, it is 0.1
