Be able to see temperature sensors under Weather tab
Posted: Tuesday 29 May 2018 21:07
by EdddieN
I use a lot of temperature sensors, and some of them are outdoors. It would be nice if I could have an option to show these under the Weather tab since this are more related to weather than indoor temperature.
Of course, having temperature tab is good, just nicer to be able to move some to the Weather tab
Re: Be able to see temperature sensors under Weather tab
Posted: Wednesday 30 May 2018 6:59
by mrf68
Or you create specific floorplan for that and have all the necessary sensors shown there.
Posted: Wednesday 30 May 2018 21:10
by EdddieN
Yes, already doing that. But I must admit I use more often the tabs for speed.
Posted: Thursday 16 August 2018 16:27
by paalkr
+1 for this request. Plans are good, but the predefined tabs are there for a reason. And it makes sense to list outdoor temperature sensors under the weather tab.
Posted: Thursday 16 August 2018 19:55
by Xztraz
or just make tabs completely custom. on each sensor set a tab it should belong to. and make tab names customizable. posibility to add remove tabs. and possibly sub tabs/groupings,
maybe use room grouping for new tabs. then the current tabs can still be there too. or possibly under a sub tab "all devices"
using more than a couple of hundred devices gets stuff quite non overviewable.
Posted: Wednesday 13 January 2021 16:45
by Xztraz
bumping this.
at least make weather tab a bit more customizable with other sensors. i have outdoor temp (temp/hum). weather prognosis (text) cloud cover (general %), light (lux) , c02, kp index (general, custom sensor) , is it raining(switch). all spread out over 4 tabs.
pretty pleeease
