X10 dim/bright command
Posted: Sunday 27 May 2018 16:39
quite new on this forum and a newbie with Domoticz too, but heave done a lot of reading and trying.
I want to control my Oase pump, and light controls of my garden pond.
I know the control-box (FM-master 3) uses some kind of X10 protocol, but it is a not the standard protocol somehow.
I contacted the supplier of my RFXtrx 433E and he supplied me the hex files needed to get the pump and lights ON/OFF.
In the dedicated software (RFXmngr) I can send commands linke dim an bright too.
If selected Lighting 1-X10, and select "dim" the pump really "dimms" (decreases its flow).
If I select the X10 protocol within Domoticz, I dont see the options "dim" or "bright" available. That is a pitty - It would save me a lot of money if I could
So my questions are:
- Does anyone know the dim+bright commands of the X10 protocol?
- Dim/bright is functional from within RFXmngr, but how do I get the same command from Domoticz send to my RFXtrx 433E?
- Does X10 have a command, that makes is possible to go to a certain amount of dim/bright? (e.g.: set dim at 50%)
- if not, is there an option for dimming within Domoticz, for a device at the dashboard with a simple "+" or "-" (for bright/dim)
- Is it possible to send these commands, if not available within Domoticz (some kind of script/command, but I'm not a script-kiddy)
Hope someone has got a clue for me
Running:
RFXtrx 433E, f/w 1021 (dedicated OASE f/w)
Connected to a Synology DS214+ NAS, DSM 6.1,
Domoticz Version: 3.9478 Compile Date: 2018-05-24 08:12:52
dzVents Version: 2.4.5
Python Version: None
Running:
