Temperature/Humidity sensor
Knibor
Domoticz version: Stable
Post by Knibor »
I'm currently use a temp/humidity sensor "Philio Technology Corporation PH-PAT02-B.eu Multisensor 2in1+"
When I add this sensor in Domotics, I can read the temperature 22,0 and humidity 65%.
Now I want to switch "on" my pellet stove when temperature is below 24 degrees Celsius.
I tried this with "Blockly" but this is not working.
What do I wrong?
Can someone help me with this!
Schermafbeelding 2018-05-27 om 15.59.23.png (53.39 KiB) Viewed 3835 times
Xztraz
Re: Temperature/Humidity sensor
Post by Xztraz »
have you set device as trigger?
something like this should work.
Joep123
Post by Joep123 »
IF cannot be only a temperature. I always add a time, like "IF TIME is not 00:00"
Verstuurd vanaf mijn MI 5 met Tapatalk
Knibor
Post by Knibor »
Hi, I tried the example that you show me, but it doesn't work?
But...how to set the device as trigger?
Do you have an example for me!
Knibor
Post by Knibor »
Schermafbeelding 2018-05-27 om 23.47.36.png (68.94 KiB) Viewed 3784 times
I also tried to add a time, it doesn't work.
Xztraz
Post by Xztraz »
mrf68
Post by mrf68 »
You’re using the If/Else If block, try the one without the blue square in the left upper corner.
Knibor
Post by Knibor »
Hi, thanks a lot, it works now.
Schermafbeelding 2018-05-28 om 23.40.54.png (115.59 KiB) Viewed 3715 times
mmjumel5
Post by mmjumel5 »
Bonjour.
Je suis étudiant et débutant dans l'IoT.
Je voudrai savoir comment envoyer la température et l'humidité vers le serveur domoticz installé sur ma raspberry pi 3.
Si j'utilise un script python pour récupérer la température et l'humidité côté raspberry, comment envoyer ces paramètres à partir de l'IDE Arduino ?
Toute suggestion allant dans ce sens me sera utile.
Merci
