i have a couple of dimmers in my kichen.
i want to make a custom dimmer switch with 100 steps that controls all (fibaro) dimmers that are on at the moment.
how can i make a dummy dimmer with 100 steps??
custom 100 step dimmer
- waaren
Re: custom 100 step dimmer
Create dummy hardware (setup -> hardware -> choose Dummy (Does nothing...) -> Add
Create virtual switch (Press button on just created Dummy hardware, choose switch -> OK)
Edit switch (on Switches tab locate just created virtual switch -> Edit -> Switch type -> Dimmer)
tiga
little strange but that does the trick!!!!thank you very mutch!!
tiga
Well first make a on/off switch.
Then convert it to a dimmer.
Why not directly a dimmer?
