light sensor polling interval gateway xiaomi
remko2000
Post by remko2000 »
there is a possibility to set somewhere an interval where every 10 minutes the lux value from the sensor inside the xiaomi gateway (v2) is forwarded to domoticz?
Re: light sensor polling interval gateway xiaomi
on my system the xiaomi Lux is a device. I am not 100% sure but if I remember correctly it was automatically created when adding the hardware to domoticz. Could you check if it is not already on your system (maybe in the unused devices area ) ?
remko2000
Post by remko2000 »
Yes it is a device and I see now that the luxvalue get updated but sometimes 1 time in an hour and sometimes 6 times. I don' t understand the logical behind this and would like to control it by myself.
remko2000 wrote: Saturday 26 May 2018 8:26 Yes it is a device and I see now that the luxvalue get updated but sometimes 1 time in an hour and sometimes 6 times. I don' t understand the logical behind this and would like to control it by myself.
It's a known gateway problem and cannot be solved by domoticz. (dirty) Workaround is to send an on/off to the internal gateway light, forcing the Lux sensor to measure the light and update it's value.
remko2000
Post by remko2000 »
Ok thx. I will try that workaround.
DAVIZINHO
Post by DAVIZINHO »
hello.
The light must be on any time? or if i set lighton and lightoff this works?
Becasue if the script set one after the other, the light not turn on and maybe is a good woorkaround :-)
