Z-UNO - Moisture probes
Posted: Thursday 24 May 2018 19:34
I use Domoticz and I have 3 moisture probes on Z-Uno.
I have have a problem for pair my 3 devices on Domoticz
I test with 3 channels ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE and it's work fine (3 devices paired)
http://fritzing.org/media/fritzing-repo ... s18b20.ino
But when I test with ZUNO_SENSOR_MULTILEVEL_TYPE_MOISTURE, only one device is paired
Can you help me please? I do not understand this case ...
My script:
Probably problem is in Domoticz? https://forum.z-wave.me/viewtopic.php?f ... 175#p76175
Thank you for your help.
My script:
int number_of_sensors = 3;
word result[3]; // Here we store probe sensors
// Define Z-Wave channels.
ZUNO_SETUP_CHANNELS(
//ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getter1),
//ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getter2),
//ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getter3)
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_MOISTURE, SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE, SENSOR_MULTILEVEL_SIZE_ONE_BYTE, SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS, getter1),
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_MOISTURE, SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE, SENSOR_MULTILEVEL_SIZE_ONE_BYTE, SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS, getter2),
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_MOISTURE, SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE, SENSOR_MULTILEVEL_SIZE_ONE_BYTE, SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS, getter3)
void setup() {
void loop() {
for (byte i = 0; i < number_of_sensors; i++) {
// Read temperature
result[i] = analogRead(3+i);
// Sending report
zunoSendReport(i + 1); // Channels starts from 1
delay(30000);
// Getters. Add more if you need more sensors
word getter1() {
return result[1];
word getter2() {
return result[2];
word getter3() {
return result[3];
