Async solution for getting openUV data with API Key (no longer kind of )
Posted: Thursday 24 May 2018 16:18
Because I could not use dzVents async openURL together with an API key to get UV and ozone data from openUV, I made a script that kind of simulates that approach with the help of a domoticz user variable.
[EDIT} no longer needed. See updated script and remarks in post 4
First get your free API key from https://www.openuv.io/ and enter that in the data section of the script.
In the same area you need to enter your longitude . latitude values and devicenumbers of your (to be created) virtual UV devices (current and max today) and of the two alerts (UV and ozone alert).
you need dzVents 2.4.0 or later to be able to use this script. Tested and working on PI-3 with Debian stretch. (domoticz V3.9476)
[EDIT & BTW] I am still considering if I will include this in my updateWeatherSensors solution. Any advice on that is appreciated.
have Fun!
--[[ openUV.lua for [ dzVents >= 2.4 ]
on = { timer = { "every 15 minutes at daytime" }, -- Triggers the getJsonPart
httpResponses = { "openUV_Response" } -- Trigger the handle Json part
logging = { level = domoticz.LOG_DEBUG,
marker = "openUV"
data = { openUV_Longitude = {initial = "x.xxxxxx" }, -- I store my longitude, latitude, APIkey, filename in data
openUV_Latitude = {initial = "xx.xxxxxx" }, -- You can get them from domoticz settings
openUV_Filename = {initial = "scripts/dzVents/data/OpenUV.json" }, -- path relative to domoticz directory
openUV_APIKey = {initial = "blablablabla1234567blablablablaa" }, -- get your free API key from https://www.openuv.io/
openUV_currentUV_device = {initial = xxx }, -- You have to create a couple of virtual devices
openUV_maxUV_device = {initial = xxx }, -- (first two as UV sensors and other two as Alert)
openUV_UV_Alert_device = {initial = xxx }, -- Remember device ID's and replace the "xxx" with them
openUV_ozone_Alert_device = {initial = xxx }, -- Look at https://www.domoticz.com/wiki/Hardware_Setup#Dummy_Hardware
-- If you need help with this
execute = function(dz, trigger)
local function UV_Index2Alert(index) -- Levels as from KNMI
local alert = dz.ALERTLEVEL_RED
if index < 3 then alert = dz.ALERTLEVEL_GREY
elseif index < 5 then alert = dz.ALERTLEVEL_GREEN
elseif index < 7 then alert = dz.ALERTLEVEL_YELLOW
elseif index < 9 then alert = dz.ALERTLEVEL_ORANGE
return alert
local function ozone2Alert(value) -- Levels as found on various WIKI pages
if value > 400 then alert = dz.ALERTLEVEL_GREY
elseif value > 340 then alert = dz.ALERTLEVEL_GREEN
elseif value > 310 then alert = dz.ALERTLEVEL_YELLOW
elseif value > 280 then alert = dz.ALERTLEVEL_ORANGE
return alert
local function getOpenUV_json()
local openUV_url = "https://api.openuv.io/api/v1/uv?lat=" .. dz.data.openUV_Latitude .. "&lng=" .. dz.data.openUV_Longitude
dz.openURL({
url = openUV_url ,
method = "GET",
callback = "openUV_Response",
headers = { ['x-access-token'] = dz.data.openUV_APIKey },
local function handleOpenUVResponse()
-- Read response into table and close file
openUVResponse = trigger.json
if openUVResponse.result.uv == nil or
openUVResponse.result.uv_max == nil or
openUVResponse.result.uv_max_time == nil or
openUVResponse.result.ozone == nil or
openUVResponse.result.safe_exposure_time.st3 == nil then
dz.log("Some values are missing; check it out",dz.LOG_ERROR)
dz.log(openUVResponse,dz.LOG_ERROR)
return
-- Update UV devices
dz.devices(dz.data.openUV_currentUV_device).updateUV(dz.utils.round(openUVResponse.result.uv,1))
dz.devices(dz.data.openUV_maxUV_device).updateUV(dz.utils.round(openUVResponse.result.uv_max,1))
-- convert to local time
local dateOutput = assert(io.popen("date -d" .. openUVResponse.result.uv_max_time .. " +%k:%M uur"))
local openUVMaxUVtime = dateOutput:read("*all")
dateOutput:close()
-- Construct Alertlevel and text and update UV alert device (type = Alert)
UV_AlertText = "Max UV index today is " .. dz.utils.round(openUVResponse.result.uv_max,1) .. " at " .. openUVMaxUVtime
dz.log("Current UV index = " .. dz.utils.round(openUVResponse.result.uv,1) .. ", " .. UV_AlertText,dz.LOG_INFO)
dz.devices(dz.data.openUV_UV_Alert_device).updateAlertSensor(UV_Index2Alert(openUVResponse.result.uv_max), UV_AlertText)
-- Construct Alertlevel and text and update ozone alert device (type = Alert)
ozoneAlertText = "Ozone (Dobson unit) is " .. openUVResponse.result.ozone .. "\n Max. exposure to sun (Skintype 3) is " ..
openUVResponse.result.safe_exposure_time.st3 .. " minutes."
dz.log(ozoneAlertText,dz.LOG_INFO)
dz.devices(dz.data.openUV_ozone_Alert_device).updateAlertSensor(ozone2Alert(openUVResponse.result.ozone), ozoneAlertText)
if trigger.isTimer then
getOpenUV_json()
have Fun!
