Youless meter with LAN interface
Posted: Sunday 20 May 2018 13:24
by Knibor
Hello, I have some questions about Domoticz with the Youless LAN Interface that I use.
In the the "Tab" Utility I can see the power measurement from the "Youless" .
The PV delivers back to the grid, and the power shows negative numbers. This is correct.
I want to switch on a heat pump when I deliver back more than 1500Watt (reading Domoticz/Utility/Youless power -1500Watt).
I used "blockly" to switch on the heat pump when I deliver more than -1500 Watt, but this is not working when I use "user variables" with a negative
number. When I set "user variabele" with a positive number, it works perfect.
Can someone help me how to solve this problem! (is this possible with "blockly" ?)
Re: Youless meter with LAN interface
Posted: Sunday 20 May 2018 20:27
by waaren
Knibor wrote: Sunday 20 May 2018 13:24
I do not use blockly very often so I am not sure that it cannot be done but I would not know how to do this in blockly.
In dzVents I would use something like
--[[ P1_delivery.lua
on = { devices = { "Power" } } ,
logging = { level = domoticz.LOG_INFO,
marker = "P1_Delivery" },
execute = function(dz,trigger)
local usage = trigger.usage
local usageDelivered = trigger.usageDelivered
if usageDelivered > 0 then
dz.log("Return to the grid: ".. usage .. " Watt",dz.LOG_INFO )
elseif usage > 0 then
dz.log("Use from the grid: ".. usage .. " Watt",dz.LOG_INFO )
dz.log("Perfect in balance with the grid: " .. usage .. " Watt",dz.LOG_INFO )
Posted: Monday 21 May 2018 10:17
by Knibor
Hello, thanks for the example.
I tried this "dzVents" code ,I only changed "dz.log("Return to the grid: ".. usage .. " Watt",dz.LOG_INFO )" to
dz.log("Return to the grid: ".. usageDelivered .. " Watt",dz.LOG_INFO ). Now I can read in the log " dzVents: Info: P1_Delivery: Return to the grid: 2183 Watt"
Now I want to see the "Return to the grid value "Watt" in a virtual device.
I create a virtual device "usageDelivered" and in devices he shows me Idx 50
I take some time to read in the Domoticz manual, but don't find the way to do it.
How can I connect this "Return to the grid value "Watt" to an virtual device with Idx 50?
Posted: Monday 21 May 2018 10:45
by waaren
Knibor wrote: Monday 21 May 2018 10:17
As always
the answer is.. it depends.
Will be something like dz.devices("usageDelivered").update.... (usageDelivered) or dz.devices("usageDelivered").update.... (tostring(usageDelivered))
The method to update the virtual device depends on with what type / subtype you defined the virtual device. For a textdevice the updatemethod is different then for a P1 or counter type. Find all available methods
here
Posted: Monday 21 May 2018 23:12
by Knibor
Hello, i made an virtual device
62 usageDelivered 00082062 1 Grid General kWh 0 kWh - - Set UnusedRename Device Log 2018-05-21 22:50:00
And ad this line "devices(Grid).updateGrid(Grid)"
See the script :
But I don't see that the the device "Grid"is updated, can you help me with this.
Posted: Tuesday 22 May 2018 0:27
by waaren
Knibor wrote: Monday 21 May 2018 23:12
@Knibor, sure. Something like this should do it
local gridDevice = dz.devices(62)
local gridValue = 0
gridValue = usageDelivered
gridValue = -usage
gridDevice.updateElectricity(gridValue) -- Assuming your device is defined as elektric (instant + counter)
Posted: Wednesday 23 May 2018 7:32
by Knibor
Hello, thanks a lot for the script.
I see now a little light on the horizon.
Everything works fine now.
Posted: Thursday 21 June 2018 22:48
by Knibor
Hi, after a while using this script, I can see the actual power in "Watts" but the "KWH counter" doesn't work.
Wat isn't correct in the script?
Can you help me with this!
