Using an IP camera with a dynamic DNS address
Posted: Saturday 19 May 2018 6:29
Version: 3.9453
Platform: Raspberry Pi 3 B+ (Stretch)
Plugin/Hardware: MySensors 2.2.0 with a Serial Gateway
I'm trying to add an old IP video camera (Airlink101 AIC250) in a remote location which is accessible using a dynamic DNS address (I'm using dyndns.org). I can easily access this camera using a browser. If I use a dyndns address, the Edit Camera/Test Connection button fails. However, if I use the current numbered IP address, the Edit Camera/Test Connection button still fails, but the Take Snapshot and the Stream Video icons in Add Camera do work.
It appears I've identified two problems:
1. Why does the Test Connection button fail when I use the current numbered IP address. I don't care too much about this since the camera does work outside of Add Camera.
2. How can I get this to work with a dynamic DNS address?
Thanks much in advance.
