How to make use of Central Scene Command Class?
Posted: Friday 18 May 2018 22:34
Hello again to all helpers out there
I am on domiticz beta 3.9390 and trying to add a Fibaro Button (FGPB-101) to my system.
The node is added as a Finaro Button and in the log I see that there are Central Scene Command Classes (CSCC) registered for it. I only got 6 or 7 devices (some switches, some alarm devices....I think - not in front of the system now...). One of it is a switch called ‚Level‘.
When i press the button once this switch ‚Level’ is switched ‚on‘. I get that event.
I changed the device config so that with 1,2 or 3 button presses an ‚on‘ command is send into the device associated groups.
Big question now is - how to work (i.e. automate) with the Central Scene Command Class?
Where does a device or node send those information?
Using dzVents (2.4.1) I tried to log ‚nValues‘ or ‚level‘ attributes of the device (‚Level‘-switch) - but failed big time - always got same values so no distinction to act upon
Does anyone of you uses a Fibaro Button or any other decive with CSCC support and has it up and running?
Where to get the information how often the button was pressed and to start different scenes based on that?
Or is maybe my set up not correct?
Questions over questions - sorry for that. Just trying to grasp the basics of CSCC and details of the Fibaro button
As usual... THANKS so much for any help or hints.
Regards.
Regards.
