[EnOcean] Help code Pressac CO2 TWP HUM
Posted: Friday 18 May 2018 20:18
by EdddieN
Hello there,
I'm trying to add this sensor to Domoticz, and on the log file I get this when pressing learn button:
2018-05-18 19:08:49.342 EnOcean: 01 (0A/07) A5 24 20 3C 80 05 03 D5 8E 00 01 FF FF FF FF 47 00
2018-05-18 19:08:49.342 EnOcean: destination: 0xffffffff RSSI: 29
2018-05-18 19:08:49.342 EnOcean: 4BS data: Sender id: 0x0503d58e Status: 00 Data: 3c
2018-05-18 19:08:49.342 EnOcean: 4BS, Variant 2 Teach-in diagram: Sender_ID: 0x0503D58E
Manufacturer: 0x3c (CLOUD_BUILDINGS_LTD)
Profile: 0x09
Type: 0x04 (GasSensor.04)
2018-05-18 19:08:49.387 EnOcean: Sender_ID 0x0503D58E already in the database
However I cannot see anything on the device list.
I tried also with a Temp/Hum only device from same supplier and that works well. Any idea how to fix this?
and then shortly after I get this:
2018-05-18 19:08:55.003 EnOcean: 01 (0A/07) A5 69 43 6B 0E 05 03 D5 8E 00 01 FF FF FF FF 50 00
2018-05-18 19:08:55.003 EnOcean: destination: 0xffffffff RSSI: 20
2018-05-18 19:08:55.003 EnOcean: 4BS data: Sender id: 0x0503d58e Status: 00 Data: 6b
and a bit later:
2018-05-18 19:38:05.209 EnOcean: 01 (0A/07) A5 00 82 7B 0A 05 0F 38 5E 00 01 FF FF FF FF 31 00
2018-05-18 19:38:05.209 EnOcean: destination: 0xffffffff RSSI: 51
2018-05-18 19:38:05.209 EnOcean: 4BS data: Sender id: 0x050f385e Status: 00 Data: 7b
so things are happening... why it not been added as a device?
Re: [EnOcean] Pressac CO2 TWP HUM
Posted: Friday 18 May 2018 20:27
by EdddieN
Ok, I can imagine is not that popular and it is not on any compatibility list?
Is there anyone that know a bit about it, happy to try get my hands dirty to try to add it. I just don't even know where to start with it.
http://www.pressac.com/enocean-co2-sens ... d-humidity
Re: [EnOcean] Help code Pressac CO2 TWP HUM
Posted: Saturday 19 May 2018 11:49
by EdddieN
Ok, I have no idea but someone coded this I guess:
https://github.com/domoticz/domoticz/bl ... anESP3.cpp
and I can see Co2 sensors here:
//A5-09: Gas Sensor
	{ 0xA5, 0x09, 0x01, "CO Sensor (not in use)",																				"GasSensor.01" },
	{ 0xA5, 0x09, 0x02, "CO-Sensor 0 ppm to 1020 ppm",																			"GasSensor.02" },
	{ 0xA5, 0x09, 0x04, "CO2 Sensor",																							"GasSensor.04" },
	{ 0xA5, 0x09, 0x05, "VOC Sensor",																							"GasSensor.05" },
	{ 0xA5, 0x09, 0x06, "Radon",																								"GasSensor.06" },
	{ 0xA5, 0x09, 0x07, "Particles",
The log fro Domoticz claims it is a GasSensor.04 which seems right (0x04)
If Domoticz is recognising it as a 04, why does it not add it to devices?
Also, the other two sensors built into the device (humidity and temperature) are no where to be seen on the log.
Any direction or pointing would be very much appreciated! I guess this code would need to be recompiled?
Posted: Saturday 19 May 2018 12:06
by waaren
What do you see if you look directly in the database ?
sqlite3 domoticz.db
.headers on
SELECT * FROM EnoceanSensors ;
and check all DeviceID in DeviceStatus table.
select * from DeviceStatus where ID in (Select distinct(DeviceID) from EnoceanSensors) ;
Posted: Saturday 19 May 2018 12:11
by EdddieN
I see this:
ID|HardwareID|DeviceID|Manufacturer|Profile|Type
1|13|018A21AF|70|2|5
2|13|0503D58E|60|9|4
3|13|050F385E|60|4|1
According to the id, it is there (58E)
by waaren
EdddieN wrote: Saturday 19 May 2018 12:11 Hello,
I see this:
or (in your case)
select * from DeviceStatus where HardwareID = 13;
Posted: Saturday 19 May 2018 12:22
by EdddieN
I get this:
sqlite> select * from DeviceStatus where HardwareID = 13;
ID|HardwareID|DeviceID|Unit|Name|Used|Type|SubType|SwitchType|Favorite|SignalLevel|BatteryLevel|nValue|sValue|LastUpdate|Order|AddjValue|AddjMulti|AddjValue2|AddjMulti2|StrParam1|StrParam2|LastLevel|Protected|CustomImage|Description|Options|Color
896|13|02D1744|0|Unknown|0|17|0|0|0|12|255|0|OFF|2018-05-17 23:21:07|903|0.0|1.0|0.0|1.0|||0|0|0|||
897|13|02D1744|1|Unknown|0|17|0|0|0|12|255|0|OFF|2018-05-17 23:21:07|904|0.0|1.0|0.0|1.0|||0|0|0|||
895|13|02D1744|2|Unknown|0|17|0|0|0|12|255|0|OFF|2018-05-17 23:21:07|902|0.0|1.0|0.0|1.0|||0|0|0|||
903|13|02D1744|3|Unknown|0|17|0|0|0|12|255|0|OFF|2018-05-17 23:21:07|910|0.0|1.0|0.0|1.0|||0|0|0|||
899|13|02D1744|4|Unknown|0|17|0|0|0|12|255|0|OFF|2018-05-17 23:21:07|906|0.0|1.0|0.0|1.0|||0|0|0|||
898|13|02D1744|10|Unknown|0|17|0|0|0|12|255|0|OFF|2018-05-17 23:21:07|905|0.0|1.0|0.0|1.0|||0|0|0|||
894|13|35361|175|Sala EnOcean|1|80|10|0|0|12|255|0|18.8|2018-05-19 11:08:39|901|0.0|1.0|0.0|1.0|||0|0|0|||
934|13|3896|0|TH EnOcean|1|82|5|0|0|12|100|0|19.0;56;1|2018-05-19 11:17:13|941|0.0|1.0|0.0|1.0|||0|0|0|||
Which matches what I can see on the device list
Posted: Saturday 19 May 2018 12:47
by waaren
Looks like there are a couple of devices added but not yet active. I have no knowledge about this type of hardware / sensors but my approach would be to try and set one of these unknown devices to active and if that would not work:
stop domoticz
make a backup of your database
remove the row from Enocean table
start domoticz
learn the sensor again
Posted: Saturday 19 May 2018 12:51
by EdddieN
I don't now yet enough, but I got the feeling this is because there's not a model for it yet here:
https://github.com/domoticz/domoticz/bl ... anESP3.cpp (using ESP3 USB dongle)
The sensor is a combined Co2 + Humidity + Temperature, so it adds the device but does not know what to do with the sensors... but again I do not know enough (yet).
Trying now your suggestion...
Posted: Saturday 19 May 2018 12:58
by EdddieN
Tried with a fresh brand new (beta) installation, same results:
2018-05-19 11:54:13.060 EnOcean: 01 (0A/07) A5 24 20 3C 80 05 03 D5 8E 00 01 FF FF FF FF 30 00
2018-05-19 11:54:13.060 EnOcean: destination: 0xffffffff RSSI: 52
2018-05-19 11:54:13.060 EnOcean: 4BS data: Sender id: 0x0503d58e Status: 00 Data: 3c
2018-05-19 11:54:13.060 EnOcean: 4BS, Variant 2 Teach-in diagram: Sender_ID: 0x0503D58E
2018-05-19 11:54:13.060 Manufacturer: 0x3c (CLOUD_BUILDINGS_LTD)
2018-05-19 11:54:13.060 Profile: 0x09
2018-05-19 11:54:13.060 Type: 0x04 (GasSensor.04)
2018-05-19 11:54:13.060 EnOcean: Sender_ID 0x0503D58E inserted in the database
2018-05-19 11:54:18.731 EnOcean: 01 (0A/07) A5 6C 61 62 0E 05 03 D5 8E 00 01 FF FF FF FF 33 00
2018-05-19 11:54:18.731 EnOcean: destination: 0xffffffff RSSI: 49
2018-05-19 11:54:18.731 EnOcean: 4BS data: Sender id: 0x0503d58e Status: 00 Data: 62
2018-05-19 11:55:16.769 EnOcean: 01 (0A/07) A5 24 20 3C 80 05 03 D5 8E 00 01 FF FF FF FF 37 00
2018-05-19 11:55:16.769 EnOcean: destination: 0xffffffff RSSI: 45
2018-05-19 11:55:16.769 EnOcean: 4BS data: Sender id: 0x0503d58e Status: 00 Data: 3c
2018-05-19 11:55:16.769 EnOcean: 4BS, Variant 2 Teach-in diagram: Sender_ID: 0x0503D58E
2018-05-19 11:55:16.769 Manufacturer: 0x3c (CLOUD_BUILDINGS_LTD)
2018-05-19 11:55:16.769 Profile: 0x09
2018-05-19 11:55:16.769 Type: 0x04 (GasSensor.04)
2018-05-19 11:55:16.769 EnOcean: Sender_ID 0x0503D58E already in the database
2018-05-19 11:56:04.403 EnOcean: 01 (0A/07) A5 7C 82 67 0E 05 03 D5 8E 00 01 FF FF FF FF 3D 00
2018-05-19 11:56:04.403 EnOcean: destination: 0xffffffff RSSI: 39
2018-05-19 11:56:04.403 EnOcean: 4BS data: Sender id: 0x0503d58e Status: 00 Data: 67
and no device added, same result, I can see the de hardware but no devices on the DB.
Posted: Saturday 19 May 2018 13:06
by waaren
Sorry to hear that. I guess it will be up to a developer then to add this now. Did you already add an issue on github for this ?
Posted: Saturday 19 May 2018 13:09
by EdddieN
I was looking at it now, but I never have used github before so quite overwhelming right now.
I just create a message here?
https://github.com/domoticz/domoticz/is ... s%3Aclosed
Posted: Saturday 19 May 2018 13:16
by waaren
Yes. Open a new issue there which as much relevant information as you have (including version, OS and the likes) and what you already investigated.
Succes !
Posted: Saturday 19 May 2018 13:22
by EdddieN
Thanks! done
Posted: Tuesday 29 May 2018 21:10
by EdddieN
Working on it and testing before resubmitting in case anyone is interested on EnOcean Co2 sensors:
https://github.com/domoticz/domoticz/pull/2424
