Message "...OpenZWave not fully initialized yet!" - what does it mean?
Posted: Friday 18 May 2018 14:37
by DomoArigato
Hello Gang.
I am on domoticz beta 3.9390 and when switching to "setup" > "hardware" I see my Aeotec z-Wave Gen5 USB stick with a red "setup"button". Clicking this brings me to my hardware list. Above the list I see an error box with "Not all Nodes have been Queried yet, OpenZWave not fully initialized yet!".
Is there any way to identify which node is not queried so far? So that I can have a look at the cuase.
Thanks a lot in advance!
Re: Message "...OpenZWave not fully initialized yet!" - what does it mean?
Posted: Friday 18 May 2018 16:31
by Egregius
Is you add this to your options.xml file it'll go a lot faster:
<Option name="AssumeAwake" value="false" />
Problem is that without that line also battery powered (thus sleeping nodes) are queried. Because they sleep they don't respond.
Posted: Friday 18 May 2018 22:20
by DomoArigato
Thanks a lot for your help.
So I can assume this message was caused by the battery devices and not due to some problem elsewhere?
I will add that line.
Thank you
Posted: Friday 18 May 2018 22:42
by Egregius
Probably yes. Don't forget to restart domoticz after the change.
And you'll need to add it after each update.
I have a copy of the options.xml file and a cp command in the start script
Posted: Saturday 19 May 2018 6:28
by DomoArigato
Good advice. Will do.
Thank you.
Posted: Saturday 19 May 2018 7:12
by Egregius
To be complete, I'm on computer now
My options.xml:
<?xml version="1.0" encoding="utf-8"?>
<!-- To be effective, this file should be placed in the user data folder specified in the Options::Create method -->
<Options xmlns='http://code.google.com/p/open-zwave/'>
<Option name="logging" value="true" />
<!-- <Option name="UserPath" value="/domoticz" /> -->
<Option name="Associate" value="true" />
<Option name="NotifyTransactions" value="false" />
<Option name="DriverMaxAttempts" value="5" />
<Option name="SaveConfiguration" value="true" />
<Option name="RetryTimeout" value="5000" /><!-- 40000 --><!-- 15000 -->
<Option name="PerformReturnRoutes" value="true" /><!-- added -->
<Option name="AssumeAwake" value="false" /><!-- added -->
<Option name="SaveLogLevel" value="3" /><!-- added -->
<Option name="QueueLogLevel" value="3" /><!-- added -->
<Option name="DumpTriggerLevel" value="3" /><!-- added -->
<Option name="NetworkKey" value="0x09, 0x05, 0x03, 0x04, 0x01, 0x06, 0x07, 0x01, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10" />
<Option name="RefreshAllUserCodes" value="false" />
<Option name="ThreadTerminateTimeout" value="5000" /><!-- 5000 -->
</Options>
Log Levels:
0 No Logging
1 All Messages
2 Fatal Messages Only
3 Error Messages and Higher
4 Warning Messages and Higher
5 Alert Messages and Higher
6 Info Messages and Higher
7 Detailed Messages and Higher
8 Debug Messages and Higher
9 Protocol Information and Higher
And in /etc/init.d/domoticz.sh:
do_start()
# Return
# 0 if daemon has been started
# 1 if daemon was already running
# 2 if daemon could not be started
cp /domoticz/options.xml /domoticz/Config/options.xml
start-stop-daemon --chuid $USERNAME --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null \
|| return 1
start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \
$DAEMON_ARGS \
|| return 2
Without the AssumeAwake line you'll see that after a restart of Domoticz in the Zwave node list all nodes will have a green checkmark. Nodes are queried one by one. The sleeping nodes are marked with a moon icon after a timeout. If you refresh the table you'll see that one by one the sleeping nodes get that icon.
With the AssumeAwake line you'll see that all sleeping devices instantly marked with a moon. Then openzwave either doesn't query them or the timeout is a lot shorter resulting in a faster available zwave network after restart.
