Problem with fibaro roller shuter fgrm222
Posted: Friday 18 May 2018 10:59
by Pvill54
I own 11 of this controllers to control blinds and usally works fine but sometimes at night when I press the wall switch to close some blind, this blind downs for a few seconds, then up opening the blind and finally close.
It only happens when I press the wall swith(togle switch) and not always.
I am using the last stable release with a USB aeon zw090 gen5.
Re: Problem with fibaro roller shuter fgrm222
Posted: Friday 18 May 2018 14:37
by Egregius
The wall switch is connected with wires to the fibaro? Or with a script?
Posted: Monday 21 May 2018 15:31
by Pvill54
The switch is connected with wires to the fibaro. I noticed the problem occours more frequently after the blinds is positioned with the planning in the switch confioguration in domoticz. When I touch the switch multiple tiomes the blinds go up or down correctly. The problem is the first time I press the switch at the morning if the blinds went down by a command in the domoticz plannig.
Posted: Tuesday 29 May 2018 10:42
by superelch
my problem is, that every time i update, restart or reinitialize the blinds goes down.
is this normal?
Posted: Tuesday 09 May 2023 19:02
by jmn4472
Hi Pvill54,
I know it is a very old thread but have you solved this issue. I am having the same issue, since the beginning, from time to time, mainly on 2 roller shutter but sometimes on all. I use a very old version of Domoticz and Debian but if I forget that issue, I never needed to update/upgrade this configuration which doesn't evolve.
Hope you will remember how you had solved it.
