timer trigger rules - between
Posted: Wednesday 16 May 2018 13:21
I try to create a new script that runs every minute between 10:00 and sunset. But when I use the following code, nothing is happening.
When I use as a test :
The script keeps working :
2018-05-16 13:14:00.517 dzVents: Info: Sunscreen: ------ Start external script: sunscreen.lua:, trigger: every 2 minutes between 12:30 and 13:00
The 'normal' is working, but I cannot have the sunset combined in this syntax?
What is wrong with the between syntax ?
timer = {'every 1 minute between 10:00 and sunset'}
timer = {'every 2 minutes between 12:30 and 13:00'}2018-05-16 13:14:00.517 dzVents: Info: Sunscreen: ------ Start external script: sunscreen.lua:, trigger: every 2 minutes between 12:30 and 13:00
The 'normal'
'every 1 minute at 12:30-13:00'What is wrong with the between syntax ?
