Commands to be carried out by the Pi 3b+
- Pieter
- Domoticz version: 4.9700
Good night Support,
Is there a way to use the Raspberry Pi 3b+, and then execute commands in Windows 10 Pro? Example: If there is no movement for 5 minutes, the monitors must dim. You do this in Windows with: Start+L (Windows-key+L)
Regards,
Pieter
English is not my language.
Forgive me if I make a language mistake
Pieter
Re: Commands to be carried out by the Pi 3b+
One way would be to setup an SSH Server on the Windows host then use something like nircmd with sshpass (apt-get install sshpass) on the Raspberry.
Eg, from the Raspberry (not exact) to execute a command on the Windows PC, it would look something like this:
sshpass -p "PASSWORD" ssh "USERNAME"@"IPOFWINDOWSCOMPUTER" "pathtonircmd.exe nircmandcommand"
https://www.nirsoft.net/utils/nircmd.html
- Egregius
- Domoticz version: v2024.7
This should do it: https://sourceforge.net/projects/winexe/
I hope it’s not judt for windows - L?
- Pieter
Good morning ben53252642,
No matter what I do, the cursor keeps flashing. But beyond that, nothing happens to the monitor.
Regards,
Pieter
Pieter
Personally I'm using this .bat file to turn the screen off on Windows 10
TurnoffScreen.bat
You can test it by pasting that code straight into cmd, be careful not to move the mouse (screens should turn off?).
TurnoffScreen.bat
powershell -WindowStyle Hidden -NonInteractive (Add-Type '[DllImport(\"user32.dll\")]^public static extern int SendMessage(int hWnd, int hMsg, int wParam, int lParam);' -Name a -Pas)::SendMessage(-1,0x0112,0xF170,2)
- Pieter
Hell yes! The screens all went out. And now in linux, can you help me a little bit?
Regards,
Pieter
Pieter
On Windows:
1) Create folder in C drive called: scripts
2) In notepad paste the contents of this:
Save the file in the scripts folder on C drive, be sure the file is named exactly: TurnoffScreen.bat
When you go file save as in notepad, you will see its by default set to save as type "Text Documents", change that to "All Files" before saving.
3) Now you should be able to double click TurnoffScreen.bat in the scripts folder and it should work.
4) You now need to remotely tell Windows to run that file when you want the screens to turn off.
5) Setup OpenSSH server on Windows so we can connect to its command line remotely from the Raspberry, suggest follow this or similar guide:
https://www.bleepingcomputer.com/news/m ... sh-server/
6) Make sure you set a static IP address on the windows PC
On Raspberry:
1) apt-get install sshpass
2) ssh -l username STATICIPADDRESSOFWINDOWSPC
3) Make sure you can login with the above command to the Windows PC.
4) Now all you have to do is tell SSH to execute a command on the host Windows PC and automate the process
Eg:
On Raspberry:
Eg:
sshpass -p "PASSWORD" ssh "USERNAME"@"IPOFWINDOWSCOMPUTER" "c:\scripts\TurnoffScreen.bat"
- Pieter
Sorry for the delay. But I fell asleep!
> On Raspberry:
I am getting an error here: Permission denied, please try again.
I can not login to my Windows 10 Pro PC, do you have any ideas?
> On Raspberry:
Regards,
Pieter
Pieter
- Pieter
No, that would be very much a waste of your and my timeEgregius wrote: ↑Wednesday 16 May 2018 6:17 This should do it: https://sourceforge.net/projects/winexe/
UPdate!!
I get one error message after another and it keeps on going. I do not get it installed. This is absolutely nothing for beginners! And that's why everything has been cleared away. With the following command: sudo rm -rf folderName. Bye bye WinExe.
https://www.raspberrypi.org/forums/view ... p?t=158795
https://www.raspberrypi.org/forums/view ... 36&t=50771
Regards,
Pieter
Pieter
