URGENT - Problem after update to 3.9390 :(
Posted: Sunday 13 May 2018 17:20
by DomoArigato
Hi all.
Just made an update from domoticz stable (3.8153) to domoticz BETA version 3.9390 on my Synology (package from jadahl.com).
All worked fine (at least as far as I cann see now...) except dzVents (which was the main reason for my updating ... oh dear.... :? ).
Got this error message:
'Error: EventSystem: in /usr/local/domoticz/var/dzVents/runtime/dzVents.lua: cannot open /usr/local/domoticz/var/dzVents/runtime/dzVents.lua: No such file or directory'
Not sure if that is why I have dzVents 2.2.0 "style" scripts from the domoticz 3.8153 (stable) version?
I restarted domoticz after update but no changes.
Has anyone an (fast) idea? Scripts are to be run soon and WAF is right now a little bit .. well... you know :shock:
Would be great if someone can point me to something.
Thanks a lot in advance.
Re: URGENT - Problem after update to 3.9390 :(
Posted: Sunday 13 May 2018 17:49
by waaren
DomoArigato wrote: Sunday 13 May 2018 17:20 Hi all.
Maybe if you extract the attached ZIP to /usr/local/domoticz/var/dzVents ?
Posted: Sunday 13 May 2018 19:18
by DomoArigato
Hmmm. That directory did not exist.
Guess that could be a reason.
Going to copy those files once I figured out how to copy from windows to that directory (Linux beginner here :) )
Going to report
Thanks.
Posted: Sunday 13 May 2018 19:40
by madpatrick
You can use WinSCP to copy files between Windows and Linux.
https://winscp.net/eng/download.php
Posted: Sunday 13 May 2018 20:20
by DomoArigato
well yes... ahm.. tried that (WinSCP) and failed so far. :shock: :roll:
When connected with WinSCP via SFTP to the Synology I can see only the mounted filesystems (like "photo", "homes", "home") but I have not figured out how to access "/usr/local/domoticzs/...". Maybe that is something I have to configure on the Synology first.
Will try to learn WinSCP first.
Posted: Sunday 13 May 2018 21:23
by jumbotroll
If you have updated from stable, the folder was not created.
You can take backup of domoticz.db and uninstall domoticz, then reinstall beta version and restore your domoticz.db and the folder will be created.
Posted: Sunday 13 May 2018 21:25
by DomoArigato
well... phhhewwwwww. I am back in business. :ugeek:
Thank you all for your help!
After the update to the beta version, the 'dzVents' directory was not around.
Had a bit of a struggle with my limited knowledge about the Synology (admin and root and chmod and things) but was able to connect via WinSCP's SCP connection, then saw the systems file system.
Was able to copy the zip-File from waaren (many thanks for that!!) and now the dzVents system seems to work again.
Now the missus is asking for my presence. :? 8-)
Regards and thanks again to everyone!
