Barometic BMP280
losholmen
Barometic BMP280
How do you configure Adafruit bmp280? I have connected gpio pin 1 and 3volt and pin 3and 5 and created a dummy in hardware, what do I do then?
- carymay
Re: Barometic BMP280
Hello,losholmen wrote: Saturday 12 May 2018 16:33 How do you configure Adafruit bmp280? I have connected gpio pin 1 and 3volt and pin 3and 5 and created a dummy in essay writer service hardware, what do I do then?
Where do I find the the Adafruit Unified Sensor library? I'm trying to install the Adafruit_BMP280 library and need a tutorial.
kimot
- Domoticz version: v3.8153
I think example here:
https://github.com/adafruit/Adafruit_BMP280_Library
is clear.
You can use spi or hardware i2c - pins depends on your processor.
http://arduinolearning.com/code/arduino ... xample.php
is clear.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
