Domoticz Lite App Androind
TheBod
Post by TheBod »
HI
Just got a new Android phone and cannot remember the settings to install the Domoticz Lite app on it. It is asking for the local server address, which i assume is 192.168.1.129:8080.
What will be the Local protocol? Http and 6144?
Do i also need to complete the Local username and directory as it says leave empty if not used?
Help
Hobbybob
Re: Domoticz Lite App Androind
Post by Hobbybob »
The server-address is just the IP-address (in your case 192.168.1.129). After that you select HTTP as the protocol, and the port-number 8080 will then automatically be selected.
If you don't have the login enabled on your Domoticz-installation (it is not enabled by default, so if you did not change it then it is disabled), you don't have to fill in a username/password.
TheBod
Post by TheBod »
Amazing, many thanks
