Multiply on/off switch change
optiserw
Post by optiserw »
I have a few switches in my system.
I want to change the status of the switches at the same time using one API command.
I am thinking about somenthing like that:
/json.htm?type=command&param=switchlight&idx=1&switchcmd=On&idx=2&switchcmd=Off&idx=3&switchcmd=Off&idx=4&switchcmd=On
How can I do that?
Pawel
SweetPants
Re: Multiply on/off switch change
Post by SweetPants »
Put your json commands in a script using curl and fire the script? You can only switch one per command
Or put the switches in a group and use a json to switch the group
optiserw
Post by optiserw »
SweetPants wrote: Thursday 03 May 2018 18:05 Put your json commands in a script using curl and fire the script? You can only switch one per command
If I put about 20 singular commands into the script, it will be executed for a long time (>20 seconds).
If I need to use 100 switches, it will be more than 1 minute!
This way isn't right, I think.
Pawel
optiserw
Post by optiserw »
waaren wrote: Thursday 03 May 2018 19:45 Or put the switches in a group and use a json to switch the group
The state of all the group members must be the same!
In my case, the states of switches are different - not equal.
This solution isn't good.
Pawel
Other options:
use a scene -- Also delays when you have many switches
use a script -- Also delays when you have many switches
the delays are not so much in domoticz as in the hardware. For virtual switches the delay is negligible
optiserw
Post by optiserw »
waaren wrote: Thursday 03 May 2018 20:34 For virtual switches the delay is negligible
Could you show me the example code for that?
Language - whatever
idx 01-100
1 pff
2 on
3 off
4 off
state random
Best regards
Pawel
code in dzVents: ( find many other examples here )
Switch sequence of devices
   on = { devices = { "Your trigger device" }           },
   execute = function(dz, trigger )
        if trigger.state ~= "Off" then
            dz.devices(1).switchOff()
            dz.devices(2).switchOn()
            dz.devices(3).switchOff()
            dz.devices(100).switchOff()
            dz.devices(1).switchOn()
optiserw
Post by optiserw »
waaren wrote: Thursday 03 May 2018 21:24 code in dzVents: ( find many other examples here )
Thank you for your suggestion.
Is it possible with python?
I have some code in python and if it can be done with it I will be grateful.
Pawel
I'm sure it can. There is a Python subforum on this board. If you post your question there it might be answered by someone skilled enough in Python
