updating user variable does not work
Posted: Wednesday 02 May 2018 16:56
by EricT
Hello all,
I hope you can help me.
I want to update a user variable with this script:
local switchName = "On signal motion sensor"
local USERVARIABLENAME = "counter1 var"
local USERVARIABLETYPE = "0"
local USERVARIABLEVALUE = "11"
if devicechanged[switchName] == 'On' then
http://192.168.2.10:8080/json.htm?type=command¶m=updateuservariable&vname=USERVARIABLENAME&vtype=USERVARIABLETYPE&vvalue=USERVARIABLEVALUE
However, it does not work and I get the following error:
Error: EventSystem: in update user value: [string " ..."]:11: expected near '/'
I have followed these instructions from the Domoticz wiki:
http://www.domoticz.com/wiki/Domoticz_A ... g_variable:
Update an existing variable
Remember to change:
USERVARIABLENAME with the name of your variable
USERVARIABLETYPE according to the table from "Store a new variable"
USERVARIABLEVALUE with the new value
Can someone please tell me what I am doing wrong?
Re: updating user variable does not work
Posted: Wednesday 02 May 2018 17:16
by McMelloW
Perhaps think about switching to dzVents. Far more easier then lua. As a fact dzVents is lua
Updating a variable in dzVents is
domoticz.variables(VarName).set(new_value)
That's all !
Posted: Wednesday 02 May 2018 17:26
by jvdz
I am wondering why you think you can use an HTTP:// link just like that in LUA and expect it will be understood.
You need to use the standard available event option in LUA for opening URLs:
commandArray['OpenURL']= 'http://192.168.2.10:8080/json.htm?type=command¶m=updateuservariable&vname='..USERVARIABLENAME..'&vtype='..USERVARIABLETYPE..'&vvalue='..USERVARIABLEVALUE
but why not simply use :
uservariables[USERVARIABLENAME] = USERVARIABLEVALUE
This is all described in this wiki page:
https://www.domoticz.com/wiki/Events#Lu ... _Interface
Jos
Posted: Thursday 03 May 2018 11:24
by EricT
Thank you both for your help, much appericiated!
I want to help my mother who is 84 and still lives on her own 60 km away from me. Therefore I want to help her and keep an eye on her, however I am totally new to Domoticz, Lua, dzVents and Blockly. I am trying to learn from what I can find on the Internet and I know some of the Python3 basics.
I have tried to create a Blockly but I can not get it not work:
http://www.domoticz.com/forum/viewtopic ... 62&t=23272. I think the Blockly script does not see the counter value as a number but as a string. Therefore I want to use an integer user variable as a workaround.
I have tried
But I get the error:
Error opening url. I thought it was caused by the "¶" in command
¶m=updateuservariable&vname=counter1 var&vtype=0&vvalue=11
I have replaced
¶m by
&dparam according to this post
viewtopic.php?t=19311#p149864 but I still get the error message with
command&dparam
I have also tried to update the user variable by using:
Unfortunately I can not get it to work either.
I finally found this to get the user variable update to work:
commandArray['Variable:'..USERVARIABLENAME] = USERVARIABLEVALUE
I prefer not to use a workaround for the Blockly using the counter value. Is it possible for you to point me in the right direction or share some advice?
Posted: Thursday 03 May 2018 12:18
by jvdz
EricT wrote: Thursday 03 May 2018 11:24
Understand the feeling and no problem to help make that happen.
Sorry about that, that was my mistake. This is indeed the correct syntax.
I would go for a single LUA script ( or DzEvents script) for this purpose as that should do it.
I gather you like to send an Email when the counter is higher than 1?
What is the exact logic you would like to apply here?
This is the script from the other topic with a few modifications but untested, and all that is needed is to add to logic to send that email?
local virtualcounter_idx = "30"
local virtualcounter_name = "counter1"
-- Get current value
count_value = tonumber(otherdevices_svalues[virtualcounter_name])
print("old value counter1= " .. count_value)
-- Calculate new value
count_value = count_value + 1
print("new value counter1= " .. count_value)
-- Update virtual counter device
ts = virtualcounter_idx .. "|0|" .. tostring(count_value)
commandArray['UpdateDevice'] = ts
print ("ts counter1= " ..ts)
Jos
Posted: Thursday 03 May 2018 14:57
by EricT
Thank you Jos, your help and understanding is much appericiated!
What I try to accomplish is to send a message (email and/or other) to me when something is wrong. For instance when there is no activity detected by the motion sensor by the time she normally is out of bed. I want to be able to set a threshold of a minimum amount of activities before that message is sent, therefore I want to use a counter to be able to set that threshold and monitor the amount of times the motion sensor was triggered within a certain timeframe.
This is what I have sofar, it updates the counter and the user variable:
count_value = tostring(otherdevices_svalues[virtualcounter_name])
-- Get old counter vanlue and add 1 to make it eaqual to the new value of the counter
x = tostring(otherdevices_svalues[virtualcounter_name])
y = x + 1
USERVARIABLEVALUE = tostring(y)
-- Update user variable "counter1 var"
One of the things I do not understand is that it looks like the user variable requires a string to be updated but the type is an integer.
Once I have the counter working I have to figure out how to use the with value threshold and timeframes .
Posted: Thursday 03 May 2018 15:27
by jvdz
EricT wrote: Thursday 03 May 2018 14:57
These sentences are a little contradictory.
The first part I do understand, about detecting no activity in the morning and could be pretty strait forward.
This is an example how that could be done with the devices you already have.
This script will send an notification when there was no activity in the last 4 hours in the morning at 10:00 : (untested)
-- this needs to be a TIME script ran each minute so name it e.g.: script_time_morningcheck.lua
local check_hh = 10
local check_mm = 00
local Max_NoAct = 4 * 60 *60 -- 4 hours = 4*60*60 seconds
local time = os.date("*t")
-- Calculate the time difference in seconds between Now and supplied time. in YY/MM/DD HH:MM:SS
function datetimedifferencenow(s)
s = s .. ":00" -- add seconds in case only hh:mm is supplied
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
t2 = os.time{year = year, month = month, day = day, hour = hour, min = minutes, sec = seconds}
difference = os.difftime(t1, t2)
return difference
-- only perfom the check at defined time
if time.hour == check_hh and time.min == check_mm then
-- check for last detect activity and when longer send notification
if datetimedifferencenow(otherdevices_lastupdate[switchName]) >= Max_NoAct then
commandArray['SendEmail'] = 'Waarschuwing geen beweging#Geen beweging gezien sinds '..otherdevices_lastupdate['switchName']..'#[email protected]'
I am not sure what you are looking for with the counter when activity is detected.
Jos
Posted: Thursday 03 May 2018 16:32
by EricT
Awesome! I will give it a try.
With the counter I want to be able to see what has happened when I get the message and to know what her daily routine is so I can tune the script to be more accurate.
something like this:
![Image]()
Posted: Thursday 03 May 2018 16:43
by jvdz
Ah ... ok understand that part. So it is not the case you want to send a notification when a certain number of detections happened as I initially understood from your post.
So the counter is working properly, which should indeed give that basic information about movement where you can apply logic on.
Jos
Posted: Thursday 03 May 2018 16:53
by EricT
Correct, I want to know what not happened when I get the notification (sorry for the confusion). I also wanted to set a minimum, e.g.
If
not triggered with a minimum of 3 between 0800 and 0900
do
send notification "activity too low between 0800 and 0900, check log and call 112"
Posted: Friday 04 May 2018 9:16
by EricT
Hi Jos,
I had three time event running during the night to test it, two of them set in a timeframe that would send the email and one not to . This morning I saw two error messages in the log:
Error: EventSystem: in night activity check: [string "-- this needs to be a TIME script ran each mi..."]:32: attempt to concatenate field 'switchName' (a nil value)
I figured it was a sytax error thus I replaced otherdevices_lastupdate['switchName'] by otherdevices_lastupdate[switchName] and now it works!
Awesome! I clearly understand you are the Yoda and the force is with you, can I be a pedawan and learn the secrets of the force?
I will do some more testing today and let you know how that worked out.
Eric
Posted: Friday 04 May 2018 9:38
by jvdz
Much to learn you still have…my old padawan. … This is just the beginning!
Glad it works for you now as that is the fun part of it!
Jos
Posted: Friday 04 May 2018 13:32
by EricT
You are absolutely right, therefore I thought I might as well start here
http://tylerneylon.com/a/learn-lua/
It says "Learn Lua in 15 minutes". Let's see how that works out.....
Posted: Friday 04 May 2018 14:38
by EricT
I have tested it today and it worked like a charm. I have added a door switch to the script because there is also a door to "escape" from the bedroom. So the script now uses a motion sensor and a door switch, if both do not have any activity within the set timeframe an email is sent.
Here is the script:
local check_hh = 10 -- 10 = 10 AM
local check_mm = 00
local switchName1 = "On signal motion sensor"
local switchName2 = "door switch"
t1 = os.time()
return difference
if datetimedifferencenow(otherdevices_lastupdate[switchName1]) >= Max_NoAct and datetimedifferencenow(otherdevices_lastupdate[switchName2]) >= Max_NoAct then
I will do some further testing and fine tuning before I install it at my mother's home.
Thank you so much master Yoda.
