Dashticz - Module - Longfonds / luchtkwaliteit (Dutch only)
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Show air quality from longfonds.nl
Available in latest BETA!
Install the beta and add this to config.js:
Settings:
config['longfonds_zipcode'] = '5654SB';
config['longfonds_housenumber'] = '3';
Width of the block (not required)
blocks['longfonds'] = {};
blocks['longfonds']['width'] = 4;
Add block to a column like:
columns[1] = {};
columns[1]['blocks'] = ['longfonds']
columns[1]['width'] = 5;
EdwinK
Re: Dashticz - Module - Longfonds / luchtkwaliteit (Dutch only)
Post by EdwinK »
Thanks. Now to find out what those numbers mean ;)
robgeerts
Post by robgeerts »
0 = good, 11 is very bad ;)
EdwinK
Post by EdwinK »
freakshock
Post by freakshock »
Cool feature Rob, thanks !
joostnl
Post by joostnl »
Works great! Could it be that width is not adjustable?
I tried:
(I think this also not work on bitcoin addin)
robgeerts
Post by robgeerts »
Just tested in latest beta and works like a charm here...
blocks['longfonds']['width'] = 12;
Derik
Post by Derik »
Thanks From my kids...
EdwinK
Post by EdwinK »
Would be nice if those numbers would represent a colour. So, with 11 the cloud will be a deep-red, and at '0' it will be a nice green.
HansieNL
Post by HansieNL »
Hello Rob,
I tried to change the cloud image using blocks['longfonds']['image'] = 'cust_lungs.png'; , but without succes. Is it a fixed image? If so, will it be possible to change it to use our own image? I've created a lungs image as you can see...
Blah blah blah
Herman-H
Post by Herman-H »
Nice feature, longfonds. I have only one question. Where can i change "Luchtkwaliteit" in "Luchtkwaliteit: 0 - goed, 11 - zeer slecht"
Update: Found it.
EdwinK
Post by EdwinK »
Looks like this isn't working anymore. Only got an empty tile. When I go to longfonds.nl, data takes forever to show
HansieNL
Post by HansieNL »
EdwinK wrote: Tuesday 11 June 2019 22:32 Looks like this isn't working anymore. Only got an empty tile. When I go to longfonds.nl, data takes forever to show
Still working here. I just tried with their own address: https://www.longfonds.nl/gezondelucht/a ... Number=127
Blah blah blah
EdwinK
Post by EdwinK »
That seems to work, yet I don't get any results on my Dashticz installation.
EastXIII
Post by EastXIII »
HansieNL wrote: Wednesday 12 June 2019 13:13
Still working here. I just tried with their own address: https://www.longfonds.nl/gezondelucht/a ... houseNumbe
Maybe you should remove this link since you just told the whole wide web where you live... I assume. But then again; assumption is the mother of all f**k ups.
EdwinK
Post by EdwinK »
HansieNL used the address from the Longfonds, not his.
EastXIII
Post by EastXIII »
Should have known... Apologies!
jake
Post by jake »
EdwinK wrote:HansieNL used the address from the Longfonds, not his.
No wonder that it worked well....
... Just kidding
EdwinK
Post by EdwinK »
tried again, still not working for me :(
BlueMotion
Post by BlueMotion »
Works like a a charm. Except the coloring part.
Code in config.js
config['longfonds_zipcode'] = '8888AA';
config['longfonds_housenumber'] = '11';
  title: 'Longfonds',
  switch: true,
  width: 3,
Besides the Longfonds I also have a Co2 Sensor, the PM10 and PM25 sensor.
For those sensors I configured the coloring based on the luchtkwaliteitsindex (air quality index)
https://www.luchtmeetnet.nl/informatie/ ... ndex-(lki)
// pm25
function getStatus_124(block){
var idx = block.idx;
var device = block.device;
   if(parseFloat(device['Data'])<10){
      block.addClass='kleurStatus1';
   if((parseFloat(device['Data'])>=10) && (parseFloat(device['Data'])<15)){
      block.addClass='kleurStatus2';
      if((parseFloat(device['Data'])>=15) && (parseFloat(device['Data'])<20)){
      block.addClass='kleurStatus3';
      if((parseFloat(device['Data'])>=20) && (parseFloat(device['Data'])<30)){
      block.addClass='kleurStatus4';
      if((parseFloat(device['Data'])>=30) && (parseFloat(device['Data'])<40)){
      block.addClass='kleurStatus5';
      if((parseFloat(device['Data'])>=40) && (parseFloat(device['Data'])<50)){
      block.addClass='kleurStatus6';
      if((parseFloat(device['Data'])>=50) && (parseFloat(device['Data'])<70)){
      block.addClass='kleurStatus7';
      if((parseFloat(device['Data'])>=70) && (parseFloat(device['Data'])<90)){
      block.addClass='kleurStatus8';
      if((parseFloat(device['Data'])>=90) && (parseFloat(device['Data'])<100)){
      block.addClass='kleurStatus9';
   if(parseFloat(device['Data'])>=100)  {
      block.addClass='kleurStatus10';
With a link to the coloring in the custom.css
/* kleuren voor luchtkwaliteit (PM10, PM25, Longfonds) */
.kleurStatus1 {
  color: royalblue !important;
.kleurStatus2 {
  color: cornflowerblue !important;
.kleurStatus3 {
  color: skyblue !important;
.kleurStatus4 {
  color: lightyellow !important;
.kleurStatus5 {
  color: khaki !important;
.kleurStatus6 {
  color: yellow !important;
.kleurStatus7 {
  color: orange !important;
.kleurStatus8 {
  color: darkorange !important;
.kleurStatus9 {
  color: orangered !important;
.kleurStatus10 {
  color: red !important;
The problem I have is that the longfonds has no idx number or whatsoever. Does any know how to color the longfonds block based on the 0-11 (great to bad) classes?
