Error /scripts/dzVents/runtime/EventHelpers.lua:69
Posted: Friday 27 April 2018 21:10
I'm on V3.8153
All of a sudden there is the error
No idea where to look at.
By chance I deactivated the following script and the error has gone.
Can't remember having changed anything, has been running fine.
Error: EventSystem: in /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua: /home/pi/domoticz/scripts/dzVents/runtime/EventHelpers.lua:69: attempt to index local 'fileStorage' (a boolean value)By chance I deactivated the following script and the error has gone.
-- assumptions:
-- the setpoint is set by a selector dummy device where the values are numeric temperatures
-- but you can easily change it to a setpoint device
local BOILER_DEVICE = 'FB 31 Infrarot' -- switch device
local SWITCH_DEVICE = 'Schalter Bad Infrarot'
local SETPOINT_DEVICE = 'Solltemperatur Bad' -- selector dummy device
local TEMPERATURE_SENSOR = 'Bad'
local HYSTERESIS = 0.5 -- temp has to drop this value below setpoint before boiler is on again
local SMOOTH_FACTOR = 3
local LOGGING = false
timer = {
'every 1 minutes',
devices = {
TEMPERATURE_SENSOR,
SETPOINT_DEVICE
data = {
temperatureReadings = { history = true, maxItems = SMOOTH_FACTOR }
active = true,
execute = function(domoticz, device, triggerInfo)
local avgTemp
local temperatureReadings = domoticz.data.temperatureReadings
-- first check if the sensor got a new reading or the setpoint was changed:
if (triggerInfo.type == domoticz.EVENT_TYPE_DEVICE) then
local sensor = domoticz.devices(TEMPERATURE_SENSOR)
if (sensor.changed) then
-- sensor just reported a new reading
-- add it to the readings table
local current = sensor.temperature
if (current ~= 0 and current ~= nil) then
temperatureReadings.add(current)
-- no need to be here, weird state detected
domoticz.log('Strange sensor reading.. skiping', domoticz.LOG_ERROR)
return
elseif (domoticz.devices(SETPOINT_DEVICE).changed) then
-- a new setpoint was set
if LOGGING then domoticz.log('Setpoint was set to ' .. device.state) end
-- no business here, bail out...
return
-- now determine what to do
local boiler = domoticz.devices(BOILER_DEVICE)
local setpoint = domoticz.devices(SETPOINT_DEVICE)
if (setpoint.state == nil or setpoint.state == 'Off') then
if boiler.state == 'On' then
boiler.switchOff()
return
return -- we're done here
local setpointValue = tonumber(setpoint.state)
-- determine at which temperature the boiler should be
-- switched on
local switchOnTemp = setpointValue - HYSTERESIS
-- don't use the current reading but average it out over
-- the past <SMOOTH_FACTOR> readings (data smoothing) to get rid of noise, wrong readings etc
local avgTemp = temperatureReadings.avg(1, SMOOTH_FACTOR)
if LOGGING then
domoticz.log('Average: ' .. avgTemp, domoticz.LOG_INFO)
domoticz.log('Setpoint: ' .. setpointValue, domoticz.LOG_INFO)
domoticz.log('Current boiler state: ' .. boiler.state, domoticz.LOG_INFO)
domoticz.log('Switch-on temperature: ' .. switchOnTemp, domoticz.LOG_INFO)
local irswitch = domoticz.devices(SWITCH_DEVICE)
if avgTemp >= setpointValue and boiler.state == 'On' or ((domoticz.time.hour < 7) or (domoticz.time.hour >= 10 )) then
if LOGGING then domoticz.log('Target temperature reached or off time, boiler off') end
boiler.switchOff()
-- elseif avgTemp < setpointValue and boiler.state == 'Off' and (domoticz.time.hour >= 7) and (domoticz.time.hour < 9 ) then
-- if LOGGING then domoticz.log('Target temperature low, boiler On') end
-- boiler.switchOn()
