SMS to Domoticz
Posted: Thursday 26 April 2018 21:26
by assenzuid
Not sure if it's possible what I wants.
I have an Alarm System (vendor Visonic) with a GSM module. The alarm system is monitored by an alarm central. When I enable or disarm the alarm system I get a notification on my GMS (through SMS). Is it possible to make use of an system that can send the SMS to my Domoticz to get the status?
Kind regards,
Re: SMS to Domoticz
Posted: Thursday 26 April 2018 23:05
by sion
You may be able to tap into the alarm panel?
I hooked up a couple of relays, and rf senders, so domoticz knows if alarm is set, disarmed, or ringing and can act accordingly. You would need to look inside and see what connections you have. Is the gsm built in? Or separate?
Re: SMS to Domoticz
Posted: Saturday 28 April 2018 12:25
by assenzuid
GSM module is build in. Have not a Ethernet module
Re: SMS to Domoticz
Posted: Saturday 28 April 2018 12:32
by jvdz
Doesn't the Alarm system have some external connect possibility with some sort of NC/NO pins to indicate its status?
If so, you could hook up an arduino board and report the status to domoticz.
Jos
Re: SMS to Domoticz
Posted: Sunday 29 April 2018 9:42
by assenzuid
That's something what I have to check.
