Enocean FSB61NP-230V do not switch
Eisenhauer
Post by Eisenhauer »
I have a Problem with my FSB61NP-230V. Datasheet:
https://www.eltako.com/fileadmin/downlo ... 0-5_dt.pdf
I installed it properly and can move my blinds with the local switch entry of the device. So I tried to integrate this in Domoticz. The result was this:
The device IDX 838 is created by domoticz and I can not switch this. This message results:
Error: EnOcean (1): Can not switch with this DeviceID, use a switch created with our id_base!...
Is this normal?
In the next step I create the manual device IDX 836 like in the wake described. I can switch this device and the LED on the FSB61NP-230V is blinking, but nothing moves. Message in domosticz:
2018-04-23 08:43:34.378 EnOcean Send: 55 00 07 00 01 11 F6 30 FF F2 AD 02 30 A1
2018-04-23 08:43:34.378 EnOcean Send: 55 00 07 00 01 11 F6 00 FF F2 AD 02 20 74
2018-04-23 08:43:34.392 (Enocean) Lighting 2 (jmnn)
2018-04-23 08:43:34.641 EnOcean: 02 (01/00) 00
2018-04-23 08:43:34.841 EnOcean: 02 (01/00) 00
Whtat is wrong?
Eisenhauer
Re: Enocean FSB61NP-230V do not switch
Maybe I use the wrong ID (I chosse the one) form the manual created switch? Should I use the 4, like the Unit number form the Enocean device?
I this possible?
Eisenhauer
Sadly no response. Because this I try FHEM and there the actor runs very good. It is possible to make this working in Domoticz. too?
