Page 1 of 2
massive logging with lua script
Posted: Sunday 22 April 2018 20:34
by timop
I have one script which check if my Home (switch) on and sets volumio to play if anyone is home or not if nobody at home (or time is over 9pm or under 10am)
it works but when it sets off volumio, it starts logging to domoticz about 10times /sec, so everything else logging goes "lost"
what I am doing wrong ?
script
if (devicechanged['Home']) then
--if (devicechanged['Home'] == 'On') then
commandArray['Volumio'] = 'On'
commandArray['Variable:VolumioVar'] = '1'
elseif (time.hour >=21 or otherdevices['Home'] == 'Off') then
commandArray['Volumio'] = 'Off'
commandArray['Variable:VolumioVar'] = '0'
elseif (time.hour <10 or otherdevices['Home'] == 'Off') then
--end
log
2018-04-22 21:33:47.026 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.078 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.130 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.182 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.233 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.285 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.337 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.389 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.442 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.493 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.545 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.597 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.650 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.702 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.755 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.806 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.860 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.909 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
2018-04-22 21:33:47.961 EventSystem: Script event triggered: /home/timo/domoticz/scripts/lua/script_device_Volumio.lua
Re: massive logging with lua script
Posted: Sunday 22 April 2018 21:28
by jvdz
The script you posted has 2 lines commented out which means the IF now works totally different:
elseif (time.hour >= 21 or otherdevices['Home'] == 'Off') then
elseif (time.hour < 10 or otherdevices['Home'] == 'Off') then
--end
This means for each device change this logic is executed and one of the Else If's is probably true!
Jos
Posted: Sunday 22 April 2018 21:46
by timop
So I need to enable that commented lines?
I did copy those devicechanged lines from some example without understanding why those where there. And i commented out because it works even commented out.
edit: I removed comments it stops that massive logging at least for now, thanks!
Posted: Sunday 22 April 2018 22:20
by jvdz
You could do it like this to avoid the continuous loop:
elseif devicechanged['Home'] == 'Off') then
-- change based on time
if (otherdevices['Volumio'] == 'On')
and (time.hour >= 21 or time.hour < 10) then
Although the second part of the script testing for the times really should be a Time script, not a Device script.
Jos
Posted: Sunday 22 April 2018 22:41
by jvdz
Fixed issue in the above code posted using otherdevices['Volumio'] in stead of devicechanged['Volumio'] for the second part.
Jos
Posted: Monday 23 April 2018 6:43
by timop
Thanks, I will test later today.
Those were in same script because of couple examples in script_device_volumio.lua
So i need to add second script_time_volumio.lua?
Posted: Friday 27 April 2018 18:24
by timop
I didnt have time to test before, but now I tested and it works almost in one script.
If clock was before 9 o'clock and home switch was switched on, it switched Volumio on, what is not good.
So I changed two separated scripts,
time = os.date("*t")
if (otherdevices['Volumio'] == 'On') and (time.hour >= 21 or time.hour < 19) then
return commandArra
and script_time_volumio.lua
elseif (devicechanged['Home'] == 'Off') then
It does turn Volumio On for a moment when time is before 9, is there a way to remove that moment, I think its a 1 minute.
Posted: Friday 27 April 2018 19:06
by jvdz
Iam confused: You have now < 19 in your posted script?
So what exactly is it you want it to do?
Is your question about adding a condition when Home is changing it also takes the time into account?
Jos
Posted: Friday 27 April 2018 19:16
by timop
sorry it left for testing because here in Finland it is evening so I am testing nearest hours.
it didnt even start when time was 20 (8pm)
I tought it will start working when someone leaves home and home switch goes off and back on. but not in my case.
what I need
if anyone is home (another script turning Home switch on) and time is between 9 am - 9pm volumio switch should be on.
if home switch is on but time is 12am-9am or 9pm -12pm volumio should be off.
if home switch is off and time is anything volumio should be off.
Posted: Friday 27 April 2018 19:49
by jvdz
It seems you have switched the logic of the Device and Time script looking at what you have posted!
Ok this script will now only change the Volumio between 9:00 and 21:00 when Home changed to On or Off:
--script_device_volumio.lua
if devicechanged['Home'] and time.hour < 21 and time.hour > 9 then
This script will ensure that Volumio is Off after 21:00 and before 09:00
and it will switch On Volumio in case it is Off and somebody is Home at 09:00.
--script_time_volumio.lua
-- switch Off when On after 21:00 till 09:00
if otherdevices['Volumio'] == 'On' and time.hour == 9) then
-- switch On when Off after 09:00 till 21:00
elseif (otherdevices['Volumio'] == 'Off' and otherdevices['Home'] == 'On' and time.hour < 21 and time.hour > 9) then
Is this more or less what you are looking for?
Jos
Posted: Friday 27 April 2018 20:49
by timop
Big Thanks!
I will test right away
Posted: Friday 27 April 2018 21:09
by timop
I changed shutoff time to 22 but it didnt switch off
but I changed line
to
if (otherdevices['Volumio'] == 'On' and time.hour > 22 and time.hour < 9) then
so now it switched off, I will check tomorrow again..
Posted: Friday 27 April 2018 21:57
by jvdz
You are right... I changed the wrong line ... the intent was to change the second condition to make it only switch On one time in the morning like this:
if otherdevices['Volumio'] == 'On' and (time.hour >= 21 or time.hour <= 9) then
elseif (otherdevices['Volumio'] == 'Off' and otherdevices['Home'] == 'On' and time.hour == 9) then
Sorry, but can test myself without a lot of effort first, so leave it to you to debug.
Jos
Posted: Friday 27 April 2018 22:07
by timop
Thats ok and I will learn same time a lot !
Posted: Saturday 28 April 2018 9:21
by timop
first I needed to change
to
if otherdevices['Volumio'] == 'On' and (time.hour >= 21 or time.hour =< 9) then
it did log ')' expected near '='
it works kind of:
- it doesnt set volumio switch off when home switch goes off.
-it does set volumio on when home switch is ON and time is before 9
-it does set volumio on when home switch goes ON and time is after 9
Posted: Saturday 28 April 2018 9:56
by jvdz
timop wrote: Saturday 28 April 2018 9:21
to
I do not see that change solving a missing ) error unless I am mistaken.
it works kind of:
This should work between 09:00 and 21:00 as outside this window it is already Off with the posted script. YOu say it doesn't do that?
This should not happen with the posted script!
So that is OK.
Could you post the current versions of both scripts and the name of the script that code is in?
It probably is best to add some debugging lines in the scripts to ensure we understand what is happening when. Will do so after you posted the current versions.
Jos
Posted: Saturday 28 April 2018 10:16
by timop
about that ) near = error, after I changed =< to <= it stopped error logging.
here are scripts.
--script_time_Volumio.lua
if (otherdevices['Volumio'] == 'On' and time.hour >= 21 and time.hour <= 9) then
--script_device_Volumio.lua
should this "time = os.date("*t")" be before or after command array?
I made one dummy switch for replacing Home, with that I can test coming home and leaving there easier.
but I have wait hourly like changing next to 12, so maybe adding minutes to time could be faster to test..
Posted: Saturday 28 April 2018 10:28
by jvdz
What time did you have this issue? :
Looking at our logic this will obviously only work between 10:00 and 20:00 as that is what we test for.
EDIT: Guess this should fix that?:
if (otherdevices['Volumio'] == 'On' and time.hour > 21 and time.hour <= 9) then
-- switch On when Off at 09:00
elseif (otherdevices['Volumio'] == 'Off' and otherdevices['Home'] == 'On' and time.hour == 9 and time.min == 0) then
if devicechanged['Home'] and time.hour < 21 and time.hour > 8 then
Jos
Posted: Saturday 28 April 2018 10:31
by timop
well it is all after 9, like now if I manually set home switch off volumio still stays On.
those variables, I may be never need those, but nice to have if I some day needed
I have also variable for Home switch..
Posted: Saturday 28 April 2018 10:39
by jvdz
Understand that 9:10 is after 9 but the hour will still be set to 9 so the previous test (time.hour > 9 ) will still be not true that is why I changed it to "> 8"!
This version has some debugging print statements which helps to identify which part of the logic runs when:
print("Set Volumio to Off because between 21:00 - 9:00 script_time_Volumio.lua")
print("Set Volumio to On because its 9:00 and Home=On script_time_Volumio.lua")
print("Device Home changed to : " .. devicechanged['Home'] .. " and it's between 9:00 and 21:00. Volumio will be set to:" .. commandArray['Volumio'] .. " script_device_Volumio.lua")
Jos
