dzVents Timer problem
Doudy
Post by Doudy »
I have a problem with timer :
That is ok :
		timer = {
			'every 5 minutes between sunset and sunrise',
2018-04-20 16:25:03.123 dzVents: Info: ------ Start external script: test8.lua:, trigger: every 5 minutes between sunset and sunrise
2018-04-20 16:25:03.123 dzVents: [-------------- Test script Lua 8 --------------]
2018-04-20 16:25:03.156 dzVents: Info: Radiation :593
2018-04-20 16:25:03.156 dzVents: Info: ------ Finished test8.lua
But the following code does not work
		timer = {
			'every 2 between 15 minutes before sunrise and 15 minutes after sunset'
Nothing in log !
An idea ?
dannybloe
Re: dzVents Timer problem
Post by dannybloe »
'every 2 minutes .. ' perhaps?
Doudy
Post by Doudy »
With
'every 2 minutes between 15 minutes before sunrise and 15 minutes after sunset'
dont working
The following does not work either
'between 15 minutes before sunset and 15 minutes after sunrise',
it seems to me that it is when using before and after that there is a problem
dannybloe
Post by dannybloe »
Which version of dzVents are you using (see Domoticz about)?
Doudy
Post by Doudy »
Version: 3.8153
Build Hash: 494fff7
Compile Date: 2017-07-30 12:19:41
dzVents (2.2.0):
Doudy
Post by Doudy »
dannybloe
Post by dannybloe »
Ah.. that's old. Doesn't support that stuff. You need at least 2.3.0 for this to work. Better use latest beta.
Doudy
Post by Doudy »
dannybloe wrote: Friday 20 April 2018 17:32 Ah.. that's old. Doesn't support that stuff. You need at least 2.3.0 for this to work. Better use latest beta.
At https://github.com/dannybloe/dzVents/releases i dont find 2.3.0 :!:
dannybloe
Post by dannybloe »
It is part of Domoticz now. Read the info page there :-)
Doudy
Post by Doudy »
OK :?
Thanks ;)
Doudy
Post by Doudy »
When i "Check for Update"
I have the following response : "No update Available !"
My version : Version: 3.8153
Update:
When i change "Release Channel in Beta"
I have the following new version
3.9269
But dzVents is always : dzVents (2.2.0):
Update 2 :
dzVents is always "DISABLED"
When I change the check (enabled) come back to (disabled) after apply settings
dannybloe
Post by dannybloe »
Try clearing your browser caches (all of them) (after you upgraded to the latest beta). And then check the Domoticz about page (not the settings as the settings will no longer show you dzVents version, that was moved to the about page).
Doudy
Post by Doudy »
dannybloe wrote: Monday 23 April 2018 7:23 Try clearing your browser caches (all of them)
OK
dannybloe wrote: Monday 23 April 2018 7:23 And then check the Domoticz about page
+ restart domoticz with
pi@RASPBERRYPI-182:~ $ sudo /etc/init.d/domoticz.sh restart
[ ok ] Restarting domoticz.sh (via systemctl): domoticz.service.
:!: No trace of dzvents :!:
Doudy
Post by Doudy »
try with Firefox
dannybloe
Post by dannybloe »
It's a cache issue.
Doudy
Post by Doudy »
Now is OK
new presentation (pretty)
Lua works
Did you clear your appcache (chrome://appcache-internals/# ) and remove appropriate item ?
Doudy
Post by Doudy »
Doudy
Post by Doudy »
But
No trace of the operation of dzvents
My script is in domoticz\scripts\dzVents\scripts
I changed the log level to Debug (everything) in settings / settings / other / dzvents
and I get the following messages:
2018-04-23 09:13:48.154 dzVents: Debug: Processing device-adapter for WH2600-Solar Radiation: Solar radiation device adapter
2018-04-23 09:13:48.154 dzVents: Debug: dzVents version: 2.4.5
2018-04-23 09:13:48.154 dzVents: Debug: Event triggers:
2018-04-23 09:13:48.154 dzVents: Debug: - Device: WH2600-Solar Radiation
2018-04-23 09:13:48.172 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:13:48.192 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:13:48.209 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:13:48.226 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:13:54.714 (RFXCOM) Temp + Humidity (T-S. de Bain)
2018-04-23 09:13:57.352 (RFXCOM) Temp + Humidity (T-Garage)
2018-04-23 09:14:00.434 dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2018-04-23 09:14:00.478 dzVents: Debug: Event triggers:
2018-04-23 09:14:00.478 dzVents: Debug: - Timer
2018-04-23 09:14:00.496 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:00.515 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:00.533 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:00.550 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:00.568 dzVents: Debug: Script dzVents_settings.lua has no "on" and/or "execute" section, not a dzVents module. Skipping
2018-04-23 09:14:03.535 dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
an idea ?
I do not understand very well
:oops:
dannybloe
Post by dannybloe »
Maybe show us your script. It is clearly wrong as the log-lines tell you.
