Tado.cpp compiler error.....
Posted: Thursday 19 April 2018 15:17
Moving to a fresh install of Ubuntu 16.04 LTS on a vmware machine. Updated everything on Ubuntu and followed the stepps in the installation guide and it worked well until around 67% when it tried to compile the Tado.CPP
Any suggestions?
Any suggestions?
In file included from /usr/include/c++/5/regex:35:0,
from /home/xyzzyx/domoticz/hardware/Tado.cpp:25:
/usr/include/c++/5/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
#error This file requires compiler and library support \
/home/xyzzyx/domoticz/hardware/Tado.cpp: In member function ‘bool CTado::MatchValueFromJSKey(std::__cxx11::string, std::__cxx11::string, std::__cxx11::string&)’:
/home/xyzzyx/domoticz/hardware/Tado.cpp:578:2: error: ‘match_results’ is not a member of ‘std’
std::match_results<std::string::const_iterator> _Matches;
/home/xyzzyx/domoticz/hardware/Tado.cpp:578:2: note: suggested alternative:
In file included from /usr/include/boost/asio/read_until.hpp:26:0,
from /usr/include/boost/asio.hpp:91,
from /home/xyzzyx/domoticz/hardware/../main/../tcpserver/TCPClient.h:3,
from /home/xyzzyx/domoticz/hardware/../main/../tcpserver/TCPServer.h:4,
from /home/xyzzyx/domoticz/hardware/../main/mainworker.h:11,
from /home/xyzzyx/domoticz/hardware/Tado.cpp:21:
/usr/include/boost/asio/detail/regex_fwd.hpp:29:7: note: ‘boost::match_results’
class match_results;
/home/xyzzyx/domoticz/hardware/Tado.cpp:578:48: error: expected primary-expression before ‘>’ token
/home/xyzzyx/domoticz/hardware/Tado.cpp:578:50: error: ‘_Matches’ was not declared in this scope
/home/xyzzyx/domoticz/hardware/Tado.cpp:581:2: error: ‘regex’ is not a member of ‘std’
std::regex _reSearch(sKeyName + ": '(.*?)'");
/home/xyzzyx/domoticz/hardware/Tado.cpp:581:2: note: suggested alternative:
In file included from /usr/include/boost/regex_fwd.hpp:27:0,
from /usr/include/boost/asio/detail/regex_fwd.hpp:20,
from /usr/include/boost/asio/read_until.hpp:26,
/usr/include/boost/regex/v4/regex_fwd.hpp:60:48: note: ‘boost::regex’
typedef basic_regex<char, regex_traits<char> > regex;
/home/xyzzyx/domoticz/hardware/Tado.cpp:582:7: error: ‘regex_search’ is not a member of ‘std’
if (!std::regex_search(sJavascriptData, _Matches, _reSearch)) {
/home/xyzzyx/domoticz/hardware/Tado.cpp:582:52: error: ‘_reSearch’ was not declared in this scope
/home/xyzzyx/domoticz/hardware/Tado.cpp: In member function ‘bool CTado::GetTadoApiEnvironment(std::__cxx11::string)’:
/home/xyzzyx/domoticz/hardware/Tado.cpp:607:2: error: ‘match_results’ is not a member of ‘std’
/home/xyzzyx/domoticz/hardware/Tado.cpp:607:2: note: suggested alternative:
/home/xyzzyx/domoticz/hardware/Tado.cpp:607:48: error: expected primary-expression before ‘>’ token
/home/xyzzyx/domoticz/hardware/Tado.cpp:607:50: error: ‘_Matches’ was not declared in this scope
CMakeFiles/domoticz.dir/build.make:3662: recipe for target 'CMakeFiles/domoticz.dir/hardware/Tado.cpp.o' failed
make[2]: *** [CMakeFiles/domoticz.dir/hardware/Tado.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
CMakeFiles/Makefile2:103: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
