Check if a site is still working
dannybloe
Post by dannybloe »
Howdee folks,
I have a couple of webservers running and at some point one of them was not working anymore so I thought it was about time to do some regular monitoring. Of course there are plenty solutions out there but I though: let's do it with dzVents. And... turns out it is very simple to do.
So, I started by creating a dummy switch 'mySiteA' that will represent the state of my website A. If the switch is Off then... well.. the site is down. I also create a switch 'testSite' so I can manually trigger a test. Then I created this script:
		timer = { 'at 09:00' },
		devices = { 'testSite' },
		httpResponses = { 'mySite'}
		if (item.isTimer or item.isDevice) then
			-- start the test
			domoticz.openURL({ url = 'http://mysite', callback = 'mySite', method = 'GET' })
		if (item.isHTTPResponse) then
			if (item.ok) then
				domoticz.email('Web server status', 'mySite is active', '[email protected]')
				domoticz.devices('mySite').switchOn()
				domoticz.email('Web server status', 'mySite is down', '[email protected]')
				domoticz.devices('mySite').switchOff()
Of course this is a simple test and it tests only one site. But you can test many sites like this and you can adjust the timer to check every hour or whatever. Also, in this case I do a simple GET request but you can also do POST requests for instance if you want to test if a contact form actually works. In the example above I test for for the ok response but you can inspect all response headers or the returned data.
Oh, and the switch mySite is just there so you can see in Domoticz the state of your site as well. In case you missed the email (you might create a script to test that as well if this is the case ;-) )
sciurius
Domoticz version: 2021.1
Re: Check if a site is still working
Post by sciurius »
Can you elaborate on this?
I'm still a novice as it comes to Domoticz scripting...
E.g. I would like to perform such a check periodically. How cna I do that?
erem
Post by erem »
@sciurius
The
is responsible for the recurrence.
for all timer options, look here: https://www.domoticz.com/wiki/DzVents:_ ... gger_rules
Regards,
Rob
sciurius
Post by sciurius »
Great, thanks!
Wilco
Domoticz version: 3.8153
Post by Wilco »
1. i created a dummy switch
2. i created a new lua-script, with only your sample
and got this error
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_http.lua: /home/pi/domoticz/scripts/lua/script_device_http.lua:7: '}' expected (to close '{' at line 1) near 'execute'
what must i do?
Kind Regards
Wilco
erem
Post by erem »
you most likely have an unmatched bracket in your code.
Regards,
Rob
Wilco
Post by Wilco »
Thanx for helping
i copied the sample code, where is the unmatched bracked? I don't see it.
Maikel76
Domoticz version: 2022.1
Post by Maikel76 »
Wilco wrote: Monday 16 August 2021 16:07 Hello,
and got this error
what must i do?
Kind Regards
Wilco
Wilco, Make a new dzVents script, not a lua script (you can choose that option too in the online editor)
Otherwise, make sure all { opening brackets are also closed with an closing bracket }
Scripting is my passion, dzVents, LUA, Bash
Dashticz v3.10.7 Beta --Raspbian Buster
Wilco
Post by Wilco »
also an error
2021-08-16 16:54:50.071 Error: dzVents: Error: (3.1.7) error loading module 'HTTP' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/HTTP.lua':
2021-08-16 16:54:50.071 ...e/pi/domoticz/scripts/dzVents/generated_scripts/HTTP.lua:7: '}' expected (to close '{' at line 1) near 'execute'
Domoticz version: 2025.1
I think the example script misses a comma
should be
Wilco
Post by Wilco »
Thank you all,
what i want is very simpel:
- 1 dummy-device (type on/off)
- check (every hour) the http(s)-response
yes = dummy-device ON
no = dummy-device OFF
does someone have a lua-script?
kiddigital
Post by kiddigital »
Check the ‘HTTP(S) Poller’ hardware module.
For more info, read the Wiki page about it.
Wilco
Post by Wilco »
Hello Kiddigital,
i saw that, but how to? can you give me a sample?
